Saltar al contenido principal
Black and Decker BV2500 Type 4 Powerhead Assembly Replacement
Qué necesitas
  1. Black and Decker BV2500 Type 4 Powerhead Assembly Replacement, Clamshell (Black Outer Casing): paso 1, imagen 1 de 1
    • Using a Phillips #2 screwdriver, remove the six 20 mm screws in the black plastic casing (clamshell).
  2. Black and Decker BV2500 Type 4 Powerhead Assembly Replacement: paso 2, imagen 1 de 2 Black and Decker BV2500 Type 4 Powerhead Assembly Replacement: paso 2, imagen 2 de 2
    • Using your hands, remove the blower tube and clamshell.
    • To remove the clamshell, pull apart starting from the bottom until it is pulled out from the notches. Then slide it out away from the device.
  3. Black and Decker BV2500 Type 4 Powerhead Assembly Replacement, Powerhead Assembly: paso 3, imagen 1 de 1
    • The powerhead assembly is the entire orange part of the device.
    • Replace it with a new powerhead assembly.
Conclusión
Angelica Chow
Miembro Desde 01/25/14
409 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 9-29, Maness Winter 2014 Miembro de Cal Poly, Team 9-29, Maness Winter 2014
CPSU-MANESS-W14S9G29
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 15
Todo El Tiempo: 1,198
