Saltar al contenido principal
Black and Decker BV2500 Type 4 Power Cord Replacement
Qué necesitas
  1. Black and Decker BV2500 Type 4 Power Cord Replacement, Clamshell (Black Outer Casing): paso 1, imagen 1 de 1
    • Using a Phillips #2 screwdriver, remove the six 20 mm screws in the black plastic casing (clamshell).
  2. Black and Decker BV2500 Type 4 Power Cord Replacement: paso 2, imagen 1 de 2 Black and Decker BV2500 Type 4 Power Cord Replacement: paso 2, imagen 2 de 2
    • Using your hands, remove the blower tube and clamshell.
    • To remove the clamshell, pull apart starting from the bottom until it is pulled out from the notches. Then slide it out away from the device.
  3. Black and Decker BV2500 Type 4 Power Cord Replacement, Power Cord: paso 3, imagen 1 de 2 Black and Decker BV2500 Type 4 Power Cord Replacement, Power Cord: paso 3, imagen 2 de 2
    • Using a Phillips #2 screwdriver, remove the ten 20 mm screws in the orange casing.
    • Use your hands to lift off the side of the orange casing with the screws facing you.
  4. Black and Decker BV2500 Type 4 Power Cord Replacement: paso 4, imagen 1 de 2 Black and Decker BV2500 Type 4 Power Cord Replacement: paso 4, imagen 2 de 2
    • Locate the switch.
    • Remove the 2 black and white wires with blue casings from the switch.
    • Using your hands, push in the sides of the switch and slide out the wires.
  5. Black and Decker BV2500 Type 4 Power Cord Replacement: paso 5, imagen 1 de 1
    • Remove the two 20 mm Phillips #2 screws that are holding in the power cord (located at the bottom of the leaf hog).
  6. Black and Decker BV2500 Type 4 Power Cord Replacement: paso 6, imagen 1 de 3 Black and Decker BV2500 Type 4 Power Cord Replacement: paso 6, imagen 2 de 3 Black and Decker BV2500 Type 4 Power Cord Replacement: paso 6, imagen 3 de 3
    • Slide the power cord support off the power cord in the direction of the leads.
    • Use your hands to pull the power cord out of the device with the lead end coming out last.
Conclusión
Angelica Chow
Miembro Desde 01/25/14
409 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 9-29, Maness Winter 2014 Miembro de Cal Poly, Team 9-29, Maness Winter 2014
CPSU-MANESS-W14S9G29
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 30
Todo El Tiempo: 3,582
