Saltar al contenido principal
Black and Decker BV2500 Type 4 Impellor (Fan) Replacement
Qué necesitas
  1. Black and Decker BV2500 Type 4 Impellor (Fan) Replacement, Clamshell (Black Outer Casing): paso 1, imagen 1 de 1
    • Using a Phillips #2 screwdriver, remove the six 20 mm screws in the black plastic casing (clamshell).
  2. Black and Decker BV2500 Type 4 Impellor (Fan) Replacement: paso 2, imagen 1 de 2 Black and Decker BV2500 Type 4 Impellor (Fan) Replacement: paso 2, imagen 2 de 2
    • Using your hands, remove the blower tube and clamshell.
    • To remove the clamshell, pull apart starting from the bottom until it is pulled out from the notches. Then slide it out away from the device.
  3. Black and Decker BV2500 Type 4 Impellor (Fan) Replacement, Impellor (Fan): paso 3, imagen 1 de 2 Black and Decker BV2500 Type 4 Impellor (Fan) Replacement, Impellor (Fan): paso 3, imagen 2 de 2
    • Locate and unscrew the ten 20 mm Phillips #2 screws in the orange casing with a Phillips #2 screwdriver.
    • Using your hands, lift off the side of the orange casing with the screws facing you.
  4. Black and Decker BV2500 Type 4 Impellor (Fan) Replacement: paso 4, imagen 1 de 1
    • Locate the fan.
    • Unscrew the 9/16" cap and nut (in the middle of the fan) with the ratcheting socket wrench.
  5. Black and Decker BV2500 Type 4 Impellor (Fan) Replacement: paso 5, imagen 1 de 1
    • Carefully use your hands to slide the fan out from the rest of the device.
    • Be careful to not lose the washer when you slide out the fan. You need it when reassembling the device.
Conclusión
3 personas más completaron esta guía.
Atlanta Nguyen
Miembro Desde 01/25/14
115 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 9-29, Maness Winter 2014 Miembro de Cal Poly, Team 9-29, Maness Winter 2014
CPSU-MANESS-W14S9G29
4 Miembros
5 Guías creadas
5 comentarios
WRONG! WRONG!! WRONG!!! On the model BV2500, there's no need to remove any screws on the BLACK fan housing nor on the ORANGE motor housing - you'll make it much harder than it needs to be. Instead, simply push the black fan housing release button on the upper handle near the power switch and the fan housing will tilt off the motor housing. Now, locate the 9/16" plastic cap nut in the middle of the fan and remove it with a socket wrench. You'll need to pry the fan free from the motor shaft. Save the washer under the fan. NOW, you can reverse the order to re-assemble the unit with a new fan. Good luck, and don't trust everything you read on the internet!
pgootos - Contestar
Please can someone help me how to replace a new fan !!! Impossible to remove from shaft model GW 250 Thank you
fenomartines - Contestar
Totally unnecessary to take apart the housing. Just simply remove the nut and pull off the impeller. Note that the nut is left hand threaded. Loosen it by turning clockwise.
It takes less than 5 minutes to remove and replace the impeller.
David W. Lamar - Contestar
ATTENTION : As comments say, BV2500 DOESN'T have screws to remove the nose. You interchange blower and sucker by pressing a release button.
You DON'T need to open the motor housing.
Just use a socket wrench CLOCKWISE to release the plastic nut in the center of the fan
Simeon - Contestar
THANK YOU @davidwlamar for this tip! "Loosen it by turning clockwise."
Toddcscar - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 56
Todo El Tiempo: 4,047
