Saltar al contenido principal
Black and Decker BL3000S Motor Fan Replacement
Qué necesitas
  1. Black and Decker BL3000S Motor Fan Replacement, Blender Base: paso 1, imagen 1 de 2 Black and Decker BL3000S Motor Fan Replacement, Blender Base: paso 1, imagen 2 de 2
    • Before disassembling the blender base, make sure the blender disconnected from any power outlet.
    • Lift the jar straight up from the base without tilting the jar.
  2. Black and Decker BL3000S Motor Fan Replacement: paso 2, imagen 1 de 1
    • Remove the top three 1/4 inch base screws using a Philip's head screwdriver.
  3. Black and Decker BL3000S Motor Fan Replacement: paso 3, imagen 1 de 2 Black and Decker BL3000S Motor Fan Replacement: paso 3, imagen 2 de 2
    • Remove the two base leg covers next to the power cord using pliers or a flat-head screwdriver.
    • This provides access to the base screws beneath.
  4. Black and Decker BL3000S Motor Fan Replacement: paso 4, imagen 1 de 1
    • Remove the following screws that secure the top and bottom halves of the base.
    • One 1/4 Phillips screw
    • One TA-20 screw
    • Both screwdrivers must have a minimum of a three inch shank (length).
    • Screwdrivers with extenders will not fit down the access holes.
  5. Black and Decker BL3000S Motor Fan Replacement: paso 5, imagen 1 de 1
    • Lift the top half of the base from the bottom half of the base to reveal the internal mechanism.
  6. Black and Decker BL3000S Motor Fan Replacement, Motor Fan: paso 6, imagen 1 de 2 Black and Decker BL3000S Motor Fan Replacement, Motor Fan: paso 6, imagen 2 de 2
    • Using pliers, remove the top nut from the fan and remove the washer.
    • Use a small towel to hold the fan in place. This makes taking off the nut easier to do.
  7. Black and Decker BL3000S Motor Fan Replacement: paso 7, imagen 1 de 1
    • Lift the fan blades from the blender base.
Conclusión
3 personas más completaron esta guía.
Andrew
Miembro Desde 10/04/12
209 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 6-34, Regan Fall 2012 Miembro de Cal Poly, Team 6-34, Regan Fall 2012
CPSU-REGAN-F12S6G34
4 Miembros
6 Guías creadas
Un comentario
mon mixeur a montre des itincelles et de la fumeé quel étape puis suivre pour le réparer
abdelkarim hassi - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 47
Todo El Tiempo: 4,427
