Saltar al contenido principal
Black and Decker BL3000S Circuit Board
Qué necesitas
  1. Black and Decker BL3000S Circuit Board, Blender Base: paso 1, imagen 1 de 2 Black and Decker BL3000S Circuit Board, Blender Base: paso 1, imagen 2 de 2
    • Before disassembling the blender base, make sure the blender disconnected from any power outlet.
    • Lift the jar straight up from the base without tilting the jar.
  2. Black and Decker BL3000S Circuit Board: paso 2, imagen 1 de 1
    • Remove the top three 1/4 inch base screws using a Philip's head screwdriver.
  3. Black and Decker BL3000S Circuit Board: paso 3, imagen 1 de 2 Black and Decker BL3000S Circuit Board: paso 3, imagen 2 de 2
    • Remove the two base leg covers next to the power cord using pliers or a flat-head screwdriver.
    • This provides access to the base screws beneath.
  4. Black and Decker BL3000S Circuit Board: paso 4, imagen 1 de 1
    • Remove the following screws that secure the top and bottom halves of the base.
    • One 1/4 Phillips screw
    • One TA-20 screw
    • Both screwdrivers must have a minimum of a three inch shank (length).
    • Screwdrivers with extenders will not fit down the access holes.
  5. Black and Decker BL3000S Circuit Board: paso 5, imagen 1 de 1
    • Lift the top half of the base from the bottom half of the base to reveal the internal mechanism.
  6. Black and Decker BL3000S Circuit Board, Circuit Board: paso 6, imagen 1 de 1
    • Once you have the base removed, the circuit board should be clearly visible inside.
  7. Black and Decker BL3000S Circuit Board: paso 7, imagen 1 de 2 Black and Decker BL3000S Circuit Board: paso 7, imagen 2 de 2
    • Remove the four screws located on the circuit board.
    • Two are on the left side.
    • Two are on the right side.
  8. Black and Decker BL3000S Circuit Board: paso 8, imagen 1 de 1
    • Remove the following soldered connections with a soldering iron:
    • Motor wires
    • Power cord wires
  9. Black and Decker BL3000S Circuit Board: paso 9, imagen 1 de 1
    • Lift the circuit board straight up to remove it from the base.
Conclusión
Una persona más ha completado esta guía.
Andrew
Miembro Desde 10/04/12
209 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 6-34, Regan Fall 2012 Miembro de Cal Poly, Team 6-34, Regan Fall 2012
CPSU-REGAN-F12S6G34
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 36
Todo El Tiempo: 4,687
