Saltar al contenido principal
Black and Decker BDERO100 Power Cord Replacement
Qué necesitas
  1. Black and Decker BDERO100 Power Cord Replacement, Chassis: paso 1, imagen 1 de 2 Black and Decker BDERO100 Power Cord Replacement, Chassis: paso 1, imagen 2 de 2
    • Use the nylon spudger to remove the rubber ring from the filter attachment section.
    • The easiest way to do this is to place the spudger sideways and pulling out the ring.
  2. Black and Decker BDERO100 Power Cord Replacement: paso 2, imagen 1 de 2 Black and Decker BDERO100 Power Cord Replacement: paso 2, imagen 2 de 2
    • Use the TR20 Torx Security bit driver to unscrew the five 18.75mm Phillips screws from the warning label side of the chassis.
  3. Black and Decker BDERO100 Power Cord Replacement: paso 3, imagen 1 de 2 Black and Decker BDERO100 Power Cord Replacement: paso 3, imagen 2 de 2
    • Grab the plastic opening tool and place it on the separation line between both sides of the chassis.
    • Separate both sides and open the device.
    • Be careful not to lose or detach any internal parts while opening the sander.
  4. Black and Decker BDERO100 Power Cord Replacement: paso 4, imagen 1 de 2 Black and Decker BDERO100 Power Cord Replacement: paso 4, imagen 2 de 2
    • Hold the chassis and separate it from the device.
  5. Black and Decker BDERO100 Power Cord Replacement, Power Cord: paso 5, imagen 1 de 3 Black and Decker BDERO100 Power Cord Replacement, Power Cord: paso 5, imagen 2 de 3 Black and Decker BDERO100 Power Cord Replacement, Power Cord: paso 5, imagen 3 de 3
    • Use the bit driver with the JIS - J1 bit to remove the two 12.5 mm phillips screws holding the cord clamp to the chassis.
  6. Black and Decker BDERO100 Power Cord Replacement: paso 6, imagen 1 de 3 Black and Decker BDERO100 Power Cord Replacement: paso 6, imagen 2 de 3 Black and Decker BDERO100 Power Cord Replacement: paso 6, imagen 3 de 3
    • Gently pull the white cable that connects the power cord to the motor to detach it.
  7. Black and Decker BDERO100 Power Cord Replacement: paso 7, imagen 1 de 2 Black and Decker BDERO100 Power Cord Replacement: paso 7, imagen 2 de 2
    • With yout hands, hold and separate the power button from the external case by pulling gently.
  8. Black and Decker BDERO100 Power Cord Replacement: paso 8, imagen 1 de 2 Black and Decker BDERO100 Power Cord Replacement: paso 8, imagen 2 de 2
    • Select the cable that connects the power button to the power button.
  9. Black and Decker BDERO100 Power Cord Replacement: paso 9, imagen 1 de 1
    • Expose the cable and lock system by removing the cover.
    • When attaching the new power cord you will need to make sure to cover this lock system with electrical tape.
  10. Black and Decker BDERO100 Power Cord Replacement: paso 10, imagen 1 de 2 Black and Decker BDERO100 Power Cord Replacement: paso 10, imagen 2 de 2
    • Push the security pin with the plastic spudger and simultaneously, pull gently on the cable to separate it from the button.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team 1-5, Sullivan Spring 2016 Miembro de USF Tampa, Team 1-5, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G5
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 627
