Saltar al contenido principal
Black and Decker BDERO100 Power Button Replacement
Qué necesitas
  1. Black and Decker BDERO100 Power Button Replacement, Chassis: paso 1, imagen 1 de 2 Black and Decker BDERO100 Power Button Replacement, Chassis: paso 1, imagen 2 de 2
    • Use the nylon spudger to remove the rubber ring from the filter attachment section.
    • The easiest way to do this is to place the spudger sideways and pulling out the ring.
  2. Black and Decker BDERO100 Power Button Replacement: paso 2, imagen 1 de 2 Black and Decker BDERO100 Power Button Replacement: paso 2, imagen 2 de 2
    • Use the TR20 Torx Security bit driver to unscrew the five 18.75mm Phillips screws from the warning label side of the chassis.
  3. Black and Decker BDERO100 Power Button Replacement: paso 3, imagen 1 de 2 Black and Decker BDERO100 Power Button Replacement: paso 3, imagen 2 de 2
    • Grab the plastic opening tool and place it on the separation line between both sides of the chassis.
    • Separate both sides and open the device.
    • Be careful not to lose or detach any internal parts while opening the sander.
  4. Black and Decker BDERO100 Power Button Replacement: paso 4, imagen 1 de 2 Black and Decker BDERO100 Power Button Replacement: paso 4, imagen 2 de 2
    • Hold the chassis and separate it from the device.
  5. Black and Decker BDERO100 Power Button Replacement, Power Button: paso 5, imagen 1 de 2 Black and Decker BDERO100 Power Button Replacement, Power Button: paso 5, imagen 2 de 2
    • Hold the power button and pull it out of the chassis.
  6. Black and Decker BDERO100 Power Button Replacement: paso 6, imagen 1 de 2 Black and Decker BDERO100 Power Button Replacement: paso 6, imagen 2 de 2
    • Select the cable that connects to the power button.
  7. Black and Decker BDERO100 Power Button Replacement: paso 7, imagen 1 de 1
    • Expose the cable and lock system by peeling off the electric cover.
    • When attaching the new power cord you will need to make sure to cover this lock system with electrical tape.
  8. Black and Decker BDERO100 Power Button Replacement: paso 8, imagen 1 de 2 Black and Decker BDERO100 Power Button Replacement: paso 8, imagen 2 de 2
    • Push the security pin with the plastic spudger and simultaneously, pull gently on the cable to separate it from the button
  9. Black and Decker BDERO100 Power Button Replacement: paso 9, imagen 1 de 2 Black and Decker BDERO100 Power Button Replacement: paso 9, imagen 2 de 2
    • Detach the black wire connected to the power button from the motor. To do this, gently pull the cable while holding the power button.
Conclusión
Equipo
USF Tampa, Team 1-5, Sullivan Spring 2016 Miembro de USF Tampa, Team 1-5, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G5
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 1,051
