Introducción
This guide is somewhat complicated. The trigger is a very important device within the device. Any number of things could have gone wrong such as a faulty wire or a damaged spring. This guide requires that the fixer has experience working with small delicate parts and has patience.
Qué necesitas
To detach the matrix attachment piece, press down on the attachment release button located at the top of the device.
Leaving your finger pressed down on the button, simply pull on the attachment to release it.
Using a JIS 1 screwdriver, unscrew seven 19mm outer screws located on the armature.
Using the same screwdriver, unscrew the 12mm outer screw located on the armature.
Grab a hold of the trigger module. Gently lift the module out of the armature.
