Saltar al contenido principal
Black and Decker BDEDMT Power Cord Replacement
Qué necesitas
  1. Black and Decker BDEDMT Power Cord Replacement, Detach Matrix Attachment: paso 1, imagen 1 de 2 Black and Decker BDEDMT Power Cord Replacement, Detach Matrix Attachment: paso 1, imagen 2 de 2
    • Remember to disconnect the device from all external power sources.
    • To detach the matrix attachment piece, press down on the attachment release button located at the top of the device.
    • Leaving your finger pressed down on the button, simply pull on the attachment to release it.
  2. Black and Decker BDEDMT Power Cord Replacement, Remove Mounting Hardware: paso 2, imagen 1 de 3 Black and Decker BDEDMT Power Cord Replacement, Remove Mounting Hardware: paso 2, imagen 2 de 3 Black and Decker BDEDMT Power Cord Replacement, Remove Mounting Hardware: paso 2, imagen 3 de 3
    • Using a JIS 1 screwdriver, unscrew seven 19mm outer screws located on the armature.
    • Using the same screwdriver, unscrew the 12mm outer screw located on the armature.
  3. Black and Decker BDEDMT Power Cord Replacement, Mounting Bracket: paso 3, imagen 1 de 2 Black and Decker BDEDMT Power Cord Replacement, Mounting Bracket: paso 3, imagen 2 de 2
    • Using the T-handle screwdriver with the JIS 1 bit, unscrew the two lower black 12mm screws.
  4. Black and Decker BDEDMT Power Cord Replacement: paso 4, imagen 1 de 2 Black and Decker BDEDMT Power Cord Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    • There will be a white cord that runs from the power cord base to the circuit board located slightly above.
    • Use the tweezers to detach the entire white cord and blue connection piece as a whole from the circuit board.
  5. Black and Decker BDEDMT Power Cord Replacement, Trigger Assembly: paso 5, imagen 1 de 2 Black and Decker BDEDMT Power Cord Replacement, Trigger Assembly: paso 5, imagen 2 de 2
    • Physically pull up on the trigger device and remove it from the armature.
    • Flip trigger device over onto its back.
  6. Black and Decker BDEDMT Power Cord Replacement, Wire Removal: paso 6, imagen 1 de 3 Black and Decker BDEDMT Power Cord Replacement, Wire Removal: paso 6, imagen 2 de 3 Black and Decker BDEDMT Power Cord Replacement, Wire Removal: paso 6, imagen 3 de 3
    • There is a screw labeled 3 located on the bottom left of the back of the trigger device.
    • Use a JIS 0 screwdriver to remove screw.
    • Gently tug on the black wire to pull the wire out of the device.
    • Now the power cord will be completely removed from the device.
Conclusión
cayla dahl
Miembro Desde 02/01/16
247 Reputación
2 Guías creadas
Equipo
UW Tacoma, Team 1-2, Rose Winter 2016 Miembro de UW Tacoma, Team 1-2, Rose Winter 2016
UWT-ROSE-W16S1G2
Miembros de 4
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 53
Todo El Tiempo: 2,435
