Saltar al contenido principal
Black and Decker 9074 Type 4 Battery Replacement
Qué necesitas
  1. Black and Decker 9074 Type 4 Battery Replacement, Battery: paso 1, imagen 1 de 3 Black and Decker 9074 Type 4 Battery Replacement, Battery: paso 1, imagen 2 de 3 Black and Decker 9074 Type 4 Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Black & Decker 9074 type 4 screwdriver that no longer holds a charge.
    • Main pieces to work on for disassembly
    • Remove the clip that holds the transmission to the body. Insert a 6mm (1/4") flat tip screwdriver underneath the clip, gently move clip upward.
  2. Black and Decker 9074 Type 4 Battery Replacement: paso 2, imagen 1 de 3 Black and Decker 9074 Type 4 Battery Replacement: paso 2, imagen 2 de 3 Black and Decker 9074 Type 4 Battery Replacement: paso 2, imagen 3 de 3
    • Once the clip is removed the transmission can be pulled of the body.
    • Move transmission away from body
    • Planetary gears inside the transmission look clean and complete.
  3. Black and Decker 9074 Type 4 Battery Replacement: paso 3, imagen 1 de 3 Black and Decker 9074 Type 4 Battery Replacement: paso 3, imagen 2 de 3 Black and Decker 9074 Type 4 Battery Replacement: paso 3, imagen 3 de 3
    • Remove plastic washer that is situated between the transmission and the body.
    • These are the three screws that need to be removed.
    • Use a Phillips #1 screwdriver on those three screws
  4. Black and Decker 9074 Type 4 Battery Replacement: paso 4, imagen 1 de 3 Black and Decker 9074 Type 4 Battery Replacement: paso 4, imagen 2 de 3 Black and Decker 9074 Type 4 Battery Replacement: paso 4, imagen 3 de 3
    • Three Phillips screws 7/8" long removed.
    • Separate the two body halves.
    • Battery, charging port and motor are clearly seen. These are just laid into the bottom half and can be easily removed.
  5. Black and Decker 9074 Type 4 Battery Replacement: paso 5, imagen 1 de 3 Black and Decker 9074 Type 4 Battery Replacement: paso 5, imagen 2 de 3 Black and Decker 9074 Type 4 Battery Replacement: paso 5, imagen 3 de 3
    • The motor is held to the contact carrier by two elongated contacts. Clearly visible is a charging Diode as we as plenty of corrosion on the positive contact.
    • Remove motor by simply pulling it away from the contact carrier
    • View of the wiring with motor removed.
  6. Black and Decker 9074 Type 4 Battery Replacement: paso 6, imagen 1 de 3 Black and Decker 9074 Type 4 Battery Replacement: paso 6, imagen 2 de 3 Black and Decker 9074 Type 4 Battery Replacement: paso 6, imagen 3 de 3
    • Top view of the wiring.
    • Use small needle nose pliers to remove cable connector from positive contact of the battery.
    • Positive wiring removed from battery.
  7. Black and Decker 9074 Type 4 Battery Replacement: paso 7, imagen 1 de 3 Black and Decker 9074 Type 4 Battery Replacement: paso 7, imagen 2 de 3 Black and Decker 9074 Type 4 Battery Replacement: paso 7, imagen 3 de 3
    • Remove the negative (bottom) wire from battery. Gently pull it off the cable connector. Hold the wire close to the connector for removal.
    • All wiring separated from the battery. It is now ready to be replaced.
    • These are all the parts disassembled for this job.
Conclusión
9 personas más completaron esta guía.
oldturkey03
Miembro Desde 09/29/10
782,258 Reputación
119 Guías creadas
Equipo
Global Fixers Miembro de Global Fixers
Community
33 Miembros
537 Guías creadas
2 comentarios
thanks. It is also useful for old TYPE 1 model 9018. But where can you find the battery?
Biller koby - Contestar
Biller koby of course like so many other things, the battery is no longer available. But we have a fix for that as well. Check this guide Repairing Black and Decker 9074 Screwdriver Battery
oldturkey03 -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 16
Ultimos 30 días: 68
Todo El Tiempo: 14,289
