Saltar al contenido principal
Bissell Swivel Rewind Pet Vacuum Belt Replacement
Qué necesitas
  1. Bissell Swivel Rewind Pet Vacuum Belt Replacement, Belt: paso 1, imagen 1 de 3 Bissell Swivel Rewind Pet Vacuum Belt Replacement, Belt: paso 1, imagen 2 de 3 Bissell Swivel Rewind Pet Vacuum Belt Replacement, Belt: paso 1, imagen 3 de 3
    • Using your Phillips #2 screwdriver, remove the six 17.5 mm screws on the front panel that holds the brush roll in place.
  2. Bissell Swivel Rewind Pet Vacuum Belt Replacement: paso 2, imagen 1 de 3 Bissell Swivel Rewind Pet Vacuum Belt Replacement: paso 2, imagen 2 de 3 Bissell Swivel Rewind Pet Vacuum Belt Replacement: paso 2, imagen 3 de 3
    • Pull the front panel to remove it and access the brush roll and the broken belt.
  3. Bissell Swivel Rewind Pet Vacuum Belt Replacement: paso 3, imagen 1 de 3 Bissell Swivel Rewind Pet Vacuum Belt Replacement: paso 3, imagen 2 de 3 Bissell Swivel Rewind Pet Vacuum Belt Replacement: paso 3, imagen 3 de 3
    • Remove the broken belt.
    • Hold the brush roll on both ends and pull it outward to remove it.
  4. Bissell Swivel Rewind Pet Vacuum Belt Replacement: paso 4, imagen 1 de 2 Bissell Swivel Rewind Pet Vacuum Belt Replacement: paso 4, imagen 2 de 2
    • Put the new belt on the metal that makes the belt turn. It is located close to the rear tire.
  5. Bissell Swivel Rewind Pet Vacuum Belt Replacement: paso 5, imagen 1 de 2 Bissell Swivel Rewind Pet Vacuum Belt Replacement: paso 5, imagen 2 de 2
    • Put the new belt on the brush roll where there is a black spot.
  6. Bissell Swivel Rewind Pet Vacuum Belt Replacement: paso 6, imagen 1 de 2 Bissell Swivel Rewind Pet Vacuum Belt Replacement: paso 6, imagen 2 de 2
    • Pull the brush roll upward and align it in its original spot.
    • This may take some force.
Conclusión
3 personas más completaron esta guía.
Kouassi Kouassi
Miembro Desde 07/23/20
187 Reputación
1 Guía escrita
Equipo
Un comentario
Ty but where do I buy the belt??
hysell64@gmail.com - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 40
Todo El Tiempo: 3,557
