Introducción
Is your Bissell SpotClean ProHeat 5207U not spraying water? It could be because of a failing water pump. Follow this guide to replace the water pump for your Bissell SpotClean ProHeat 5207U.
Qué necesitas
Remove the marked 19.7 mm screws on the underside of the device using the Phillips #00 screwdriver.
2 personas más completaron esta guía.
