Introducción
Is the water tank on your Bissell SpotClean ProHeat 5207U leaking? It could be because of a failing float gasket. Follow this guide to replace the float gasket on your Bissell SpotClean ProHeat 5207U .
Qué necesitas
Position the device so that you can see the text at the bottom saying "SpotClean ProHeat."
Remove the dirty water tank located to the right.
3 personas más completaron esta guía.
