Saltar al contenido principal
Bissell SmartClean 1605 Roller Brush Replacement
Qué necesitas
  1. Bissell SmartClean 1605 Roller Brush Replacement, Roller Brush: paso 1, imagen 1 de 1
    • Make sure your device is powered off.
  2. Bissell SmartClean 1605 Roller Brush Replacement: paso 2, imagen 1 de 1
    • Gently flip device over.
  3. Bissell SmartClean 1605 Roller Brush Replacement: paso 3, imagen 1 de 3 Bissell SmartClean 1605 Roller Brush Replacement: paso 3, imagen 2 de 3 Bissell SmartClean 1605 Roller Brush Replacement: paso 3, imagen 3 de 3
    • Remove plastic plate cover to reveal brush roller.
  4. Bissell SmartClean 1605 Roller Brush Replacement: paso 4, imagen 1 de 2 Bissell SmartClean 1605 Roller Brush Replacement: paso 4, imagen 2 de 2
    • Remove brush roller from its slots on either side.
    • Apply pressure to one side and pull the roller out of its opposite slot.
    • It's like taking out a spring loaded toilet paper holder.
Conclusión
Austin Maranville
Miembro Desde 09/26/17
117 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S7-G4, Banghart Fall 2017 Miembro de Cal Poly, Team S7-G4, Banghart Fall 2017
CPSU-BANGHART-F17S7G4
5 Miembros
5 Guías creadas
13 comentarios
What if mine don't feel spring loaded and the brushe seems like it was just wants to fall out
Brian - Contestar
I'm having the same issue. The spring is not reloading to the brush just falls out
Rachel -
Same issue with mine. Took it apart and found that the side with spring loaded holder was broken.
Ryan Beaudre - Contestar
I am having the same issue it’s like a part is missing for the pin side not the square sides to hold the brush roll in place.
Geoffrey Fraser - Contestar
I have the same issue…it seems that the spring part was lost.have anyone of you find a replacement parts?
Mazinger Z - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 10
Todo El Tiempo: 1,025
