Saltar al contenido principal
Bissell SmartClean 1605 Front Cover Replacement
Qué necesitas
  1. Bissell SmartClean 1605 Front Cover Replacement, Front Cover: paso 1, imagen 1 de 1
    • Power off your device
  2. Bissell SmartClean 1605 Front Cover Replacement: paso 2, imagen 1 de 1
    • Flip your device and unscrew the marked screws using a phillips screwdriver.
  3. Bissell SmartClean 1605 Front Cover Replacement: paso 3, imagen 1 de 3 Bissell SmartClean 1605 Front Cover Replacement: paso 3, imagen 2 de 3 Bissell SmartClean 1605 Front Cover Replacement: paso 3, imagen 3 de 3
    • Gently pry off the top half of the front cover
    • Remove the wires from the socket.
    • Don't pull the wires too hard, they can become disconnected from the plastic plug.
  4. Bissell SmartClean 1605 Front Cover Replacement: paso 4, imagen 1 de 3 Bissell SmartClean 1605 Front Cover Replacement: paso 4, imagen 2 de 3 Bissell SmartClean 1605 Front Cover Replacement: paso 4, imagen 3 de 3
    • Once the top cover is removed, pry off the bottom casing.
Conclusión
Equipo
Cal Poly, Team S7-G4, Banghart Fall 2017 Miembro de Cal Poly, Team S7-G4, Banghart Fall 2017
CPSU-BANGHART-F17S7G4
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 204
