Saltar al contenido principal
Bissell PowerForce Compact Belt Replacement
Qué necesitas
  1. Bissell PowerForce Compact Belt Replacement, Belt: paso 1, imagen 1 de 3 Bissell PowerForce Compact Belt Replacement, Belt: paso 1, imagen 2 de 3 Bissell PowerForce Compact Belt Replacement, Belt: paso 1, imagen 3 de 3
    • Remove the 5 screws from the brush plate with the phillips screwdriver.
  2. Bissell PowerForce Compact Belt Replacement: paso 2, imagen 1 de 2 Bissell PowerForce Compact Belt Replacement: paso 2, imagen 2 de 2
    • Lift off the brush plate by grabbing both ends of the plate and lifting the plate up.
  3. Bissell PowerForce Compact Belt Replacement: paso 3, imagen 1 de 3 Bissell PowerForce Compact Belt Replacement: paso 3, imagen 2 de 3 Bissell PowerForce Compact Belt Replacement: paso 3, imagen 3 de 3
    • Grab the rotating brush at both ends.
    • Lift the rotating brush straight out of the vacuum.
    • Remove the belt from the motor pulley.
  4. Bissell PowerForce Compact Belt Replacement: paso 4, imagen 1 de 2 Bissell PowerForce Compact Belt Replacement: paso 4, imagen 2 de 2
    • Clear the bottom of the vacuum from any debris that may be blocking air flow.
    • Clean the rotating brush from any wrapped string or hair. You can use scissors if needed.
  5. Bissell PowerForce Compact Belt Replacement: paso 5, imagen 1 de 3 Bissell PowerForce Compact Belt Replacement: paso 5, imagen 2 de 3 Bissell PowerForce Compact Belt Replacement: paso 5, imagen 3 de 3
    • Check the new belt for any damage.
    • Place the belt on the rotating brush and then the motor pulley.
  6. Bissell PowerForce Compact Belt Replacement: paso 6, imagen 1 de 3 Bissell PowerForce Compact Belt Replacement: paso 6, imagen 2 de 3 Bissell PowerForce Compact Belt Replacement: paso 6, imagen 3 de 3
    • Pull the rotating brush with the belt hooked.
    • Place the ends of the rotating brush into the slots.
    • Rotate the brush a few times to center the belt.
Conclusión
4 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 45
Todo El Tiempo: 5,131
