Saltar al contenido principal
Introducción
The Bissell Pet Hair Eraser power button commands the vacuum on and off. Before disassembling the case to check the power button for proper operation, visit our troubleshooting guide for vacuum won’t turn on.
Partes
No se especificaron partes.
  1. Firmly grasp the handle and press the release button. Gently pull the dirt cup down and away from the vacuum body.
    • Firmly grasp the handle and press the release button.
    • Gently pull the dirt cup down and away from the vacuum body.
  2. Remove the six 1.2 mm Philips #2 screws in the shown locations. Remove the six 1.2 mm Philips #2 screws in the shown locations.
    • Remove the six 1.2 mm Philips #2 screws in the shown locations.
  3. Baterías para ordenadores portátiles
    Un pequeño arreglo para un gran resultado.
    Comprar Ahora
    Comprar Ahora
  4. Grasp each half of the body and gently pull apart. The green handle, power button, charge light lens, and dirt cup release are not fastened in place.
    • Grasp each half of the body and gently pull apart.
    • The green handle, power button, charge light lens, and dirt cup release are not fastened in place.
    • Once the case is split apart these items may come dislodged.
  5. The power button can be removed by gently lifting it off the circuitry. The power button can be removed by gently lifting it off the circuitry. The power button can be removed by gently lifting it off the circuitry.
    • The power button can be removed by gently lifting it off the circuitry.
Conclusión
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 1
Últimos 30 Días: 5
Todo El Tiempo: 81
