Saltar al contenido principal
Bissell Pet Hair Eraser Motorized Brush Belt Replacement
Qué necesitas
  1. Bissell Pet Hair Eraser Motorized Brush Belt Replacement, Motorized Brush: paso 1, imagen 1 de 2 Bissell Pet Hair Eraser Motorized Brush Belt Replacement, Motorized Brush: paso 1, imagen 2 de 2
    • Turn power OFF.
    • Detach motorized brush from the vacuum.
  2. Bissell Pet Hair Eraser Motorized Brush Belt Replacement: paso 2, imagen 1 de 2 Bissell Pet Hair Eraser Motorized Brush Belt Replacement: paso 2, imagen 2 de 2
    • Use a spudger or a coin to turn the circular lock clockwise to unlock the brush roll.
    • Remove the lock cover.
  3. Bissell Pet Hair Eraser Motorized Brush Belt Replacement: paso 3, imagen 1 de 1
    • Lift brush out of the enclosure.
  4. Bissell Pet Hair Eraser Motorized Brush Belt Replacement: paso 4, imagen 1 de 3 Bissell Pet Hair Eraser Motorized Brush Belt Replacement: paso 4, imagen 2 de 3 Bissell Pet Hair Eraser Motorized Brush Belt Replacement: paso 4, imagen 3 de 3
    • Remove the four 13.0 mm Phillips #0 screws and remove the green cover.
  5. Bissell Pet Hair Eraser Motorized Brush Belt Replacement: paso 5, imagen 1 de 1
    • Take out the motor assembly.
  6. Bissell Pet Hair Eraser Motorized Brush Belt Replacement, Motorized Brush Belt: paso 6, imagen 1 de 1
    • Take the belt off the gear by using a spudger.
  7. Bissell Pet Hair Eraser Motorized Brush Belt Replacement: paso 7, imagen 1 de 3 Bissell Pet Hair Eraser Motorized Brush Belt Replacement: paso 7, imagen 2 de 3 Bissell Pet Hair Eraser Motorized Brush Belt Replacement: paso 7, imagen 3 de 3
    • Grab the new belt and slide it on to the two gears.
    • Place the motor assembly back into the motorized brush enclosure.
Conclusión
To reassemble your device, follow the motorized brush disassembly instructions in reverse order.
Roman Dyagilev
Miembro Desde 11/11/17
217 Reputación
2 Guías creadas
Equipo
IUPUI, Team S4-G4, Wilson Fall 2017 Miembro de IUPUI, Team S4-G4, Wilson Fall 2017
IUPUI-WILSON-F17S4G4
3 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 409
