Saltar al contenido principal
Bissell Pet Hair Eraser Motherboard Replacement
Qué necesitas
  1. Bissell Pet Hair Eraser Motherboard Replacement, Dirt Cup: paso 1, imagen 1 de 2 Bissell Pet Hair Eraser Motherboard Replacement, Dirt Cup: paso 1, imagen 2 de 2
    • Firmly grasp the handle and press the release button.
    • Gently pull the dirt cup down and away from the vacuum body.
  2. Bissell Pet Hair Eraser Motherboard Replacement, Power Button: paso 2, imagen 1 de 2 Bissell Pet Hair Eraser Motherboard Replacement, Power Button: paso 2, imagen 2 de 2
    • Remove the six 1.2 mm Philips #2 screws from the handle and base.
  3. Bissell Pet Hair Eraser Motherboard Replacement: paso 3, imagen 1 de 2 Bissell Pet Hair Eraser Motherboard Replacement: paso 3, imagen 2 de 2
    • Grasp each half of the body and gently pull apart.
    • The green handle, power button, charge light lens, and dirt cup release are not fastened in place.
    • Once the case is split apart these items may come dislodged.
  4. Bissell Pet Hair Eraser Motherboard Replacement: paso 4, imagen 1 de 3 Bissell Pet Hair Eraser Motherboard Replacement: paso 4, imagen 2 de 3 Bissell Pet Hair Eraser Motherboard Replacement: paso 4, imagen 3 de 3
    • The power button can be removed by gently lifting it off the circuitry.
  5. Bissell Pet Hair Eraser Motherboard Replacement, Motherboard: paso 5, imagen 1 de 2 Bissell Pet Hair Eraser Motherboard Replacement, Motherboard: paso 5, imagen 2 de 2
    • Remove the battery plastic hold down by lifting it off the tabs.
    • Remove the battery by lifting straight up.
    • Position the battery aside.
  6. Bissell Pet Hair Eraser Motherboard Replacement: paso 6, imagen 1 de 3 Bissell Pet Hair Eraser Motherboard Replacement: paso 6, imagen 2 de 3 Bissell Pet Hair Eraser Motherboard Replacement: paso 6, imagen 3 de 3
    • Grasp the charger port and remove it by lifting it straight out of the case.
    • Set the charger port next to the battery.
  7. Bissell Pet Hair Eraser Motherboard Replacement: paso 7, imagen 1 de 2 Bissell Pet Hair Eraser Motherboard Replacement: paso 7, imagen 2 de 2
    • Remove the power button and charge LED light by gently pulling straight out of the case.
    • The vacuum motor can be removed by pulling straight out of the case.
    • All internals are now removed.
    • Set the case halves aside.
  8. Bissell Pet Hair Eraser Motherboard Replacement: paso 8, imagen 1 de 1
    • Remove the two 1 mm Phillips #2 screws in the shown locations.
  9. Bissell Pet Hair Eraser Motherboard Replacement: paso 9, imagen 1 de 2 Bissell Pet Hair Eraser Motherboard Replacement: paso 9, imagen 2 de 2
    • Disconnect the power leads from the vacuum motor.
    • The red power lead goes on the terminal with the visible red dot.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 351
