Introducción
Motors can break down, or clog up over time, and need to be replaced or removed for cleaning. This guide will show you how to remove the motor and circuit board.
Grab hold of both the flex hose handle  and the extension wand.
  • Grab hold of both the flex hose handle and the extension wand.
  • Pull straight out to detach the handle from the extension wand.
Agregar Comentario
Locate the lock clip on the other end of the flex hose.
  • Locate the lock clip on the other end of the flex hose.
- color code this step to match the red indicator
-watch out for the lighting (hard shadows)
Austin Marshall - Contestar
  • Hold down the lock clip to unlock the flex hose from the vacuum.
  • Remove the flex hose from the vacuum.
Agregar Comentario
  • After removing hose, place vacuum on back and unclip the top compartment.
  • Open the compartment.
  • Pull the dirt collection box out of the vacuum.
Agregar Comentario
  • Place dirt collection box to the side.
  • Locate the Pre-Motor Filter.
  • Pull the filter out by grabbing the pull tab on top.
Agregar Comentario
  • Turn vacuum around and locate the filter cover on the bottom.
  • Place fingers in the opening and pull off the filter cover.
  • Place fingers on each tab on the Post-Motor HEPA Media Filter and pull out.
Agregar Comentario
  • Take filter out to clean or replace.
  • To clean Dirt Collection Box, unlatch lid and take off.
Agregar Comentario
  • Flip Dirt Collection Box over and locate the push tab.
  • Push the Dirt Cup HEPA Media Filter up to take it off.
  • Picture 3 Shows all the filters taken out of the vacuum.
Agregar Comentario
  • Unscrew the two screws underneath the dirt collection box inside the vacuum.
  • Flip over vacuum.
Agregar Comentario
  • Unscrew both screws on the bottom of the handle.
- dark lighting (black screw against black medium)
  • Unscrew both screws near the wheels.
- missing period
  • Flip over vacuum.
  • Gently lift off top.
  • Do not try to take off completely. There are still wires attached to the hull.
- keep extra items out of frame
- missing period
  • Locate the circuit board.
- missing period
  • Unplug each orange plug.
  • Make sure you remember which orange plug goes where!
- missing period
  • Unplug the red wires. The wires may be a little difficult to take off. If they are, you may use a pair of pliers to pull the wires off.
  • Make sure not to wiggle the wires, as that may break the metal holding them.
Agregar Comentario
  • Remove the top.
- missing period
  • Unscrew the top two screws on the vacuum.
- missing period
-add indicator
- hard shadows
  • Unscrew the back two scews.
- blurry image
- hard shadows
-indicators
- black screwdriver against black medium
  • Lift motor and move it over the gain access to the spool.
  • Unscrew the screw on the spool.
  • Remove the plastic circle.
- missing period
- 2nd picture excess?
  • Remove the motor.
  • And you are done!
- you are not done after completion of this step.
Conclusión
Mathis Weyrich
Miembro Desde 18/01/18
267 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S12-G1, Banghart Winter 2018 Miembro de Cal Poly, Team S12-G1, Banghart Winter 2018
CPSU-BANGHART-W18S12G1
5 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 6
Todo El Tiempo: 72
