Saltar al contenido principal
Bionaire BAP 600 Air Filter Replacement
  1. Bionaire BAP 600 Air Filter Replacement, Base/Intake: paso 1, imagen 1 de 1
    • Rotate base counterclockwise, supporting top with opposite hand.
  2. Bionaire BAP 600 Air Filter Replacement: paso 2, imagen 1 de 1
    • Pull base away from housing exposing air filter.
  3. Bionaire BAP 600 Air Filter Replacement, Air Filter: paso 3, imagen 1 de 1
    • Grab the edge of the filter housing and pull the filter away from the rest of the device.
  4. Bionaire BAP 600 Air Filter Replacement: paso 4, imagen 1 de 1
    • Gently pull apart each fold of the filter to check for abrasions or other anomalies. Clean with a dust rag if necessary.
Conclusión
Una persona más ha completado esta guía.
Nick Miller
Miembro Desde 10/26/16
167 Reputación
3 Guías creadas
Equipo
IUPUI, Team 4-4, Baechle Fall 2016 Miembro de IUPUI, Team 4-4, Baechle Fall 2016
IUPUI-BAECHLE-F16S4G4
5 Miembros
7 Guías creadas
3 comentarios
Bonjour.merci pour le tutoriel,mais où trouver un filtre…
Frederic Battele - Contestar
Where such a filter can be bought? I was in Italy when I order mine from Amazon (UK) but can't find the filter to replace, I damaged mine.
Any idea?
Nuno Filipe - Contestar
I been searching for 3 years now. They don't make them. You have to buy a new one. I went to Honeywell and not had a problem.
Blake PS -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 24
Todo El Tiempo: 2,451
