Introducción
More often than not, the hose component of the bidet sprayer is usually the thing that is damaged unintentionally. It is typically damaged due to an awkward resting position or from extensive use. The hose may start to leak while the rest of the components such as the sprayer itself is still functional.
This is guide will highlight the steps required to safely uninstall the bidet from the toilet and then replacing the hose from the sprayer.
Turn off the main water valve under the toilet.
Rotate it clockwise until it is completely shut.
To prevent further leaks, rest the device in a manner so that the hose is not stretched extensively or placed in a twisted position.
