Saltar al contenido principal
Bicycle Handlebar Tape Replacement
Qué necesitas
  1. Bicycle Handlebar Tape Replacement, Handlebar Tape: paso 1, imagen 1 de 3 Bicycle Handlebar Tape Replacement, Handlebar Tape: paso 1, imagen 2 de 3 Bicycle Handlebar Tape Replacement, Handlebar Tape: paso 1, imagen 3 de 3
    • Undo the brake cables holding the brake calipers under tension.
    • Depress the brake/shift levers (brifters) and insert a 5mm Allen key into the internal bolt. This bolt secures the brifters to the handlebar.
    • With the 5mm Allen key, loosen and temporarily remove brifters.
  2. Bicycle Handlebar Tape Replacement: paso 2, imagen 1 de 3 Bicycle Handlebar Tape Replacement: paso 2, imagen 2 de 3 Bicycle Handlebar Tape Replacement: paso 2, imagen 3 de 3
    • Remove the old tape and discard.
    • Pour some rubbing alcohol on the rag and clean any old adhesive residue off the handlebar.
  3. Bicycle Handlebar Tape Replacement: paso 3, imagen 1 de 3 Bicycle Handlebar Tape Replacement: paso 3, imagen 2 de 3 Bicycle Handlebar Tape Replacement: paso 3, imagen 3 de 3
    • Starting on the right side of the handlebar, wrap the new tape around the end in a clockwise direction moving inward.
    • Be sure to wrap the tape tight, but don't pull so hard that it rips!
    • Using the scissors, cut the tape at an angle towards the outside of the bar.
    • Wrap the loose end with either electrical tape or the adhesive piece provided with the handlebar tape (pictured here)
  4. Bicycle Handlebar Tape Replacement: paso 4, imagen 1 de 3 Bicycle Handlebar Tape Replacement: paso 4, imagen 2 de 3 Bicycle Handlebar Tape Replacement: paso 4, imagen 3 de 3
    • On the left side of the handlebar, wrap the tape around the end in a counter-clockwise direction moving inward.
    • Wrap tight, but don't rip!
    • Wrap the loose end with either electrical tape or the adhesive piece provided with the handlebar tape (pictured).
  5. Bicycle Handlebar Tape Replacement: paso 5, imagen 1 de 2 Bicycle Handlebar Tape Replacement: paso 5, imagen 2 de 2
    • Using the 5mm Allen key, reattach and tighten the brifter levers onto the handlebar.
  6. Bicycle Handlebar Tape Replacement: paso 6, imagen 1 de 2 Bicycle Handlebar Tape Replacement: paso 6, imagen 2 de 2
    • Reattach the brake cables to the brifters and brake calipers
    • Depress the brake levers a couple of times to test and confirm that the cables were reinstalled properly before riding.
Linea de Meta
Una persona más ha completado esta guía.
Jordan Byrnes
Miembro Desde 05/05/17
132 Reputación
1 Guía escrita
Equipo
UC Davis, Team S1-G70, Coad Spring 2017 Miembro de UC Davis, Team S1-G70, Coad Spring 2017
UCD-COAD-S17S1G70
Miembros de 3
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 4
Todo El Tiempo: 612
