Saltar al contenido principal
Besta Super 5000 Motherboard Replacement
Qué necesitas
  1. Besta Super 5000 Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the device over so that the barcode is facing upwards.
  2. Besta Super 5000 Motherboard Replacement: paso 2, imagen 1 de 2 Besta Super 5000 Motherboard Replacement: paso 2, imagen 2 de 2
    • Place your fingers on the battery cover arrow and pull the cover down and off the device.
  3. Besta Super 5000 Motherboard Replacement: paso 3, imagen 1 de 1
    • Pull upwards on the battery tab to remove the battery from the device.
  4. Besta Super 5000 Motherboard Replacement, Back Cover: paso 4, imagen 1 de 1
    • Remove the five screws around the edge of the device using a Phillips #0 screwdriver.
  5. Besta Super 5000 Motherboard Replacement: paso 5, imagen 1 de 1
    • Remove the two screws behind the battery using a Phillips #0 screwdriver.
  6. Besta Super 5000 Motherboard Replacement: paso 6, imagen 1 de 2 Besta Super 5000 Motherboard Replacement: paso 6, imagen 2 de 2
    • Potential for device damage: All screws must be removed before you begin this step. Do not forcefully pry apart the device with screws still in it because you may damage it.
    • Gently pry off the backing using an opening tool.
  7. Besta Super 5000 Motherboard Replacement, Motherboard: paso 7, imagen 1 de 1
    • Remove the three silver screws from the black round battery using a Phillips #0 screwdriver.
  8. Besta Super 5000 Motherboard Replacement: paso 8, imagen 1 de 1
    • Remove the five small screws from the motherboard using a Phillips #0 screwdriver.
  9. Besta Super 5000 Motherboard Replacement: paso 9, imagen 1 de 3 Besta Super 5000 Motherboard Replacement: paso 9, imagen 2 de 3 Besta Super 5000 Motherboard Replacement: paso 9, imagen 3 de 3
    • Using a pair of tweezers, pinch the center of the yellow ribbon located in the corner of the device.
    • Potential for device damage: Do not yank or remove the ribbon from the device.
    • Carefully pull the hidden piece of yellow ribbon out from underneath the motherboard.
  10. Besta Super 5000 Motherboard Replacement: paso 10, imagen 1 de 2 Besta Super 5000 Motherboard Replacement: paso 10, imagen 2 de 2
    • Potential for device damage: All screws must be removed before you begin this step. Do not forcefully pry apart the motherboard with screws still in it because you may damage it.
    • Carefully pry off the motherboard with an opening tool.
  11. Besta Super 5000 Motherboard Replacement: paso 11, imagen 1 de 1
    • Take the motherboard out of the body frame.
  12. Besta Super 5000 Motherboard Replacement: paso 12, imagen 1 de 2 Besta Super 5000 Motherboard Replacement: paso 12, imagen 2 de 2
    • Lift the black keyboard mat off of the motherboard.
    • Replace the motherboard.
Conclusión
Una persona más ha completado esta guía.
Jessie
Miembro Desde 09/30/14
370 Reputación
3 Guías creadas
Equipo
Ohio State, Team 1-5, Buehl Fall 2014 Miembro de Ohio State, Team 1-5, Buehl Fall 2014
OSU-BUEHL-F14S1G5
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 12
Todo El Tiempo: 369
