Saltar al contenido principal
BenQ HT1075 Projector Lamp Replacement
Qué necesitas
  1. BenQ HT1075 Projector Lamp Replacement, Lamp: paso 1, imagen 1 de 1
    • Loosen the 2.5 mm Phillips #1 screw that holds the top assembly in place using a Philips #1 (PH1) screwdriver. This will enable you to lift and slide off the top cover.
    • Fully remove the top cover in order to get to the lamp housing.
  2. BenQ HT1075 Projector Lamp Replacement: paso 2, imagen 1 de 1
    • Carefully peel off the adhesive film covering the lamp housing.
  3. BenQ HT1075 Projector Lamp Replacement: paso 3, imagen 1 de 1
    • Using a Phillips #1 (PH1) screwdriver, loosen and remove the single 2.5 mm Phillips #1 screw that secures the lamp housing to the projector.
  4. BenQ HT1075 Projector Lamp Replacement: paso 4, imagen 1 de 1
    • Remove the lamp from the projector by pulling on the lamp handle.
    • Apply more force on the side opposite of the newly removed screw as you pull the lamp out.
Conclusión
3 personas más completaron esta guía.
Equipo
Cal Poly, Team S6-G1, Banghart Fall 2017 Miembro de Cal Poly, Team S6-G1, Banghart Fall 2017
CPSU-BANGHART-F17S6G1
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 26
Todo El Tiempo: 1,525
