Saltar al contenido principal
Bem Wireless HL2739B Charging Base Battery Replacement
Qué necesitas
  1. Bem Wireless HL2739B Charging Base Battery Replacement, Charging Base Battery: paso 1, imagen 1 de 1
    • Peel the rubber cover back from the corner of the auxiliary charging base to reveal the screw.
  2. Bem Wireless HL2739B Charging Base Battery Replacement: paso 2, imagen 1 de 2 Bem Wireless HL2739B Charging Base Battery Replacement: paso 2, imagen 2 de 2
    • Use the J1 bit attached to the screwdriver to remove the four 10mm screws from the bottom of the auxiliary charging base.
  3. Bem Wireless HL2739B Charging Base Battery Replacement: paso 3, imagen 1 de 1
    • Lift the bottom cover away from the rest of the auxiliary charging base.
    • There are wires connecting the battery and cover to the rest of the auxiliary charging base. Be careful when removing the auxiliary charging base cover.
  4. Bem Wireless HL2739B Charging Base Battery Replacement: paso 4, imagen 1 de 2 Bem Wireless HL2739B Charging Base Battery Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Using the tweezers, pull the wires from the auxiliary charging base's internal chip.
    • Be careful not to damage the chip when you remove the wires.
    • It will likely require soldering to reassemble the auxiliary charging base after this step.
Conclusión
Ryan McQueeney
Miembro Desde 02/28/17
446 Reputación
4 Guías creadas
Equipo
USF Tampa, Team S2-G4, Nance Spring 2017 Miembro de USF Tampa, Team S2-G4, Nance Spring 2017
USFT-NANCE-S17S2G4
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 1,930
