Saltar al contenido principal
Bem Wireless HL2739B Speaker Motherboard Replacement
Qué necesitas
  1. Bem Wireless HL2739B  Speaker Motherboard Replacement, Speaker Battery: paso 1, imagen 1 de 1
    • Peel the rubber cover back from the corner of the speaker to reveal the screw.
    • Repeat for the three remaining corners.
  2. Bem Wireless HL2739B  Speaker Motherboard Replacement: paso 2, imagen 1 de 3 Bem Wireless HL2739B  Speaker Motherboard Replacement: paso 2, imagen 2 de 3 Bem Wireless HL2739B  Speaker Motherboard Replacement: paso 2, imagen 3 de 3
    • Use the J1 bit attached to the screwdriver to remove the four 10mm screws from the bottom of the speaker.
  3. Bem Wireless HL2739B  Speaker Motherboard Replacement: paso 3, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Lift the bottom cover away from the rest of the speaker.
    • There are wires connecting the battery and cover to the rest of the speaker. Be careful when removing the base cover.
    • Using the tweezers, pull the wires from the speaker's internal chip.
    • Be careful not to damage the chip when you remove the wires.
    • It will likely require soldering to reassemble the speaker after this step.
  4. Bem Wireless HL2739B  Speaker Motherboard Replacement: paso 4, imagen 1 de 1
    • Using a plastic opening tool, gently pry the battery from the metal base.
  5. Bem Wireless HL2739B  Speaker Motherboard Replacement: paso 5, imagen 1 de 1
    • Using tweezers, pull the wires from the metal base connection.
  6. Bem Wireless HL2739B  Speaker Motherboard Replacement, Speaker Motherboard: paso 6, imagen 1 de 2 Bem Wireless HL2739B  Speaker Motherboard Replacement, Speaker Motherboard: paso 6, imagen 2 de 2
    • Unscrew the four 10mm screws from the motherboard.
  7. Bem Wireless HL2739B  Speaker Motherboard Replacement: paso 7, imagen 1 de 2 Bem Wireless HL2739B  Speaker Motherboard Replacement: paso 7, imagen 2 de 2
    Comprar
    • Using tweezers, remove the blue/white and red/black wires from motherboard.
  8. Bem Wireless HL2739B  Speaker Motherboard Replacement: paso 8, imagen 1 de 2 Bem Wireless HL2739B  Speaker Motherboard Replacement: paso 8, imagen 2 de 2
    • Gently re-position the motherboard so you can access the bus wire connected to the speaker.
    • Remove bus wire from the speaker and lift out the motherboard.
Conclusión
3 personas más completaron esta guía.
Ryan McQueeney
Miembro Desde 02/28/17
446 Reputación
4 Guías creadas
Equipo
USF Tampa, Team S2-G4, Nance Spring 2017 Miembro de USF Tampa, Team S2-G4, Nance Spring 2017
USFT-NANCE-S17S2G4
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 939
