Saltar al contenido principal
Bell and Howell DNV16HDZ Lens Assembly Replacement
Qué necesitas
  1. Bell and Howell DNV16HDZ Lens Assembly Replacement, Lens Assembly: paso 1, imagen 1 de 2 Bell and Howell DNV16HDZ Lens Assembly Replacement, Lens Assembly: paso 1, imagen 2 de 2
    • Remove the five 30mm Phillips #0 screws on the bottom of the camera.
  2. Bell and Howell DNV16HDZ Lens Assembly Replacement: paso 2, imagen 1 de 1
    • Use a plastic opening tool to disconnect the internal hinges that snaps the camera into place.
    • Using a plastic opening tool is important since a metal one will scratch or damage the thin plastic hinges that hold the camera together.
  3. Bell and Howell DNV16HDZ Lens Assembly Replacement: paso 3, imagen 1 de 1
    • It will still be connected by a plastic film. This can also be disconnected by pulling up the white part where it connects to the light circuit board.
Conclusión
Una persona más ha completado esta guía.
Jerry Hadjah
Miembro Desde 03/04/16
525 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 8-4, Botvin Spring 2016 Miembro de UMass Dartmouth, Team 8-4, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G4
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 206
