Saltar al contenido principal
Belkin NetCam HD Speaker Replacement
Qué necesitas
  1. Belkin NetCam HD Speaker Replacement, Case: paso 1, imagen 1 de 1
    • Use a wrench to loosen up the stand from the back in order to hold the NetCam more comfortably.
  2. Belkin NetCam HD Speaker Replacement: paso 2, imagen 1 de 1
    • Work a plastic opening tool into the seam and pry the face plate away from the back panel.
  3. Belkin NetCam HD Speaker Replacement: paso 3, imagen 1 de 2 Belkin NetCam HD Speaker Replacement: paso 3, imagen 2 de 2
    • Use pressure to separate the covers.
    • When pulling the device apart, separate from the bottom up in order to avoid pulling the wiring at the top apart.
  4. Belkin NetCam HD Speaker Replacement, Front Casing: paso 4, imagen 1 de 1
    • Carefully use your fingers to gently pull out the white attachment from the tan colored part.
  5. Belkin NetCam HD Speaker Replacement, Speaker: paso 5, imagen 1 de 2 Belkin NetCam HD Speaker Replacement, Speaker: paso 5, imagen 2 de 2
    • Use a Phillips #0 screwdriver to take out the two 1.2 mm screws on the board.
  6. Belkin NetCam HD Speaker Replacement: paso 6, imagen 1 de 3 Belkin NetCam HD Speaker Replacement: paso 6, imagen 2 de 3 Belkin NetCam HD Speaker Replacement: paso 6, imagen 3 de 3
    • With your fingers, pull the circuit board out of the back casing.
    • When pulling the board up be sure to do so carefully so you do not break the cord which is attached on the back side.
  7. Belkin NetCam HD Speaker Replacement: paso 7, imagen 1 de 2 Belkin NetCam HD Speaker Replacement: paso 7, imagen 2 de 2
    • Gently pull the speaker out of the holder from the back of the cover.
  8. Belkin NetCam HD Speaker Replacement: paso 8, imagen 1 de 1
    • The speaker wires are attached with the board. It can be unattached gently by pulling out the white attachment from the port.
Conclusión
Equipo
USF Tampa, Team 3-5, Sullivan Fall 2016 Miembro de USF Tampa, Team 3-5, Sullivan Fall 2016
USFT-SULLIVAN-F16S3G5
Miembros de 4
14 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 13
Todo El Tiempo: 369
