Saltar al contenido principal
Belkin NetCam HD Microphone Replacement
Qué necesitas
  1. Belkin NetCam HD Microphone Replacement, Case: paso 1, imagen 1 de 1
    • Use a wrench to loosen up the stand from the back in order to hold the NetCam more comfortably.
  2. Belkin NetCam HD Microphone Replacement: paso 2, imagen 1 de 1
    • Work a plastic opening tool into the seam and pry the face plate away from the back panel.
  3. Belkin NetCam HD Microphone Replacement: paso 3, imagen 1 de 2 Belkin NetCam HD Microphone Replacement: paso 3, imagen 2 de 2
    • Use pressure to separate the covers.
    • When pulling the device apart, separate from the bottom up in order to avoid pulling the wiring at the top apart.
  4. Belkin NetCam HD Microphone Replacement, Microphone: paso 4, imagen 1 de 2 Belkin NetCam HD Microphone Replacement, Microphone: paso 4, imagen 2 de 2
    • Use tweezers to gently pull out the white attachment from the port.
    • Use your fingers to pull out the white attachment from the tan port on the front of the board a little.
  5. Belkin NetCam HD Microphone Replacement: paso 5, imagen 1 de 2 Belkin NetCam HD Microphone Replacement: paso 5, imagen 2 de 2
    • Use a pair of tweezers to wedge between the mic and the rubber guard to remove the mic from the front cover.
    • If the rubber guard comes off with the mic just remove the guard from mic and place back on the front cover.
Conclusión
Equipo
USF Tampa, Team 3-5, Sullivan Fall 2016 Miembro de USF Tampa, Team 3-5, Sullivan Fall 2016
USFT-SULLIVAN-F16S3G5
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 305
