Saltar al contenido principal
Belkin NetCam HD Lens Piece Replacement
Qué necesitas
  1. Belkin NetCam HD Lens Piece  Replacement, Case: paso 1, imagen 1 de 1
    • Use a wrench to loosen up the stand from the back in order to hold the NetCam more comfortably.
  2. Belkin NetCam HD Lens Piece  Replacement: paso 2, imagen 1 de 1
    • Work a plastic opening tool into the seam and pry the face plate away from the back panel.
  3. Belkin NetCam HD Lens Piece  Replacement: paso 3, imagen 1 de 2 Belkin NetCam HD Lens Piece  Replacement: paso 3, imagen 2 de 2
    • Use pressure to separate the covers.
    • When pulling the device apart, separate from the bottom up in order to avoid pulling the wiring at the top apart.
  4. Belkin NetCam HD Lens Piece  Replacement, Front Casing: paso 4, imagen 1 de 1
    • Carefully use your fingers to gently pull out the white attachment from the tan colored part.
  5. Belkin NetCam HD Lens Piece  Replacement, Speaker: paso 5, imagen 1 de 2 Belkin NetCam HD Lens Piece  Replacement, Speaker: paso 5, imagen 2 de 2
    • Use a Phillips #0 screwdriver to take out the two 1.2 mm screws on the board.
  6. Belkin NetCam HD Lens Piece  Replacement: paso 6, imagen 1 de 3 Belkin NetCam HD Lens Piece  Replacement: paso 6, imagen 2 de 3 Belkin NetCam HD Lens Piece  Replacement: paso 6, imagen 3 de 3
    • With your fingers, pull the circuit board out of the back casing.
    • When pulling the board up be sure to do so carefully so you do not break the cord which is attached on the back side.
  7. Belkin NetCam HD Lens Piece  Replacement: paso 7, imagen 1 de 2 Belkin NetCam HD Lens Piece  Replacement: paso 7, imagen 2 de 2
    • Gently pull the speaker out of the holder from the back of the cover.
  8. Belkin NetCam HD Lens Piece  Replacement: paso 8, imagen 1 de 1
    • The speaker wires are attached with the board. It can be unattached gently by pulling out the white attachment from the port.
  9. Belkin NetCam HD Lens Piece  Replacement, Lens Piece: paso 9, imagen 1 de 2 Belkin NetCam HD Lens Piece  Replacement, Lens Piece: paso 9, imagen 2 de 2
    • Flip the circuit board to the back side.
    • Fold down the tape with your finger.
    • With the Phillips #0 screwdriver, unscrew the two 1.2 mm screws.
  10. Belkin NetCam HD Lens Piece  Replacement: paso 10, imagen 1 de 2 Belkin NetCam HD Lens Piece  Replacement: paso 10, imagen 2 de 2
    • Flip the circuit board back to the other side.
    • Unscrew the screw with a Phillips #0 screw driver.
  11. Belkin NetCam HD Lens Piece  Replacement: paso 11, imagen 1 de 1
    • Slide the attached piece from the lens holder device.
  12. Belkin NetCam HD Lens Piece  Replacement: paso 12, imagen 1 de 2 Belkin NetCam HD Lens Piece  Replacement: paso 12, imagen 2 de 2
    • Use the tweezers to pull the white attachment out from the port a little.
    • Then, take your fingers and gently pull the white attachment out from the tan port.
Conclusión
Equipo
USF Tampa, Team 3-5, Sullivan Fall 2016 Miembro de USF Tampa, Team 3-5, Sullivan Fall 2016
USFT-SULLIVAN-F16S3G5
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 980
