Introducción
This guide will walk you through how to replace the whole circuit board on the NetCam.
Qué necesitas
Use a wrench to loosen up the stand from the back in order to hold the NetCam more comfortably.
Use a Phillips #0 screwdriver to take out the two 1.2 mm screws on the board.
Flip the circuit board to the back side.
Fold down the tape with your finger.
With the Phillips #0 screwdriver, unscrew the two 1.2 mm screws.
On the back of the board pull the switch slowly upward to take it off.
Una persona más ha completado esta guía.
