Saltar al contenido principal
Belkin F5L114 Battery Replacement
Qué necesitas
  1. Belkin F5L114 Battery Replacement, Battery: paso 1, imagen 1 de 3 Belkin F5L114 Battery Replacement, Battery: paso 1, imagen 2 de 3 Belkin F5L114 Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Switch the power button that is located at the bottom left of the keyboard to Off.
  2. Belkin F5L114 Battery Replacement: paso 2, imagen 1 de 2 Belkin F5L114 Battery Replacement: paso 2, imagen 2 de 2
    • Flip the keyboard over.
  3. Belkin F5L114 Battery Replacement: paso 3, imagen 1 de 3 Belkin F5L114 Battery Replacement: paso 3, imagen 2 de 3 Belkin F5L114 Battery Replacement: paso 3, imagen 3 de 3
    • Pull back gently on the left side of the bottom-left rubber foot enough to expose the small screw.
  4. Belkin F5L114 Battery Replacement: paso 4, imagen 1 de 1
    • Use a Phillips #0 screwdriver to unscrew the screw.
    • The screw may not come fully out of the device.
  5. Belkin F5L114 Battery Replacement: paso 5, imagen 1 de 1
    • Pull back gently on the bottom left corner of the middle rubber foot enough to expose the small screw.
  6. Belkin F5L114 Battery Replacement: paso 6, imagen 1 de 1
  7. Belkin F5L114 Battery Replacement: paso 7, imagen 1 de 2 Belkin F5L114 Battery Replacement: paso 7, imagen 2 de 2
    • Pull back gently on the right side of the bottom-right rubber enough to expose the small screw.
  8. Belkin F5L114 Battery Replacement: paso 8, imagen 1 de 1
  9. Belkin F5L114 Battery Replacement: paso 9, imagen 1 de 2 Belkin F5L114 Battery Replacement: paso 9, imagen 2 de 2
    • Insert the spudger into the space next to the right screw area.
    • Gently pry open the battery case.
  10. Belkin F5L114 Battery Replacement: paso 10, imagen 1 de 3 Belkin F5L114 Battery Replacement: paso 10, imagen 2 de 3 Belkin F5L114 Battery Replacement: paso 10, imagen 3 de 3
    • Gently pry the battery cover off.
  11. Belkin F5L114 Battery Replacement: paso 11, imagen 1 de 2 Belkin F5L114 Battery Replacement: paso 11, imagen 2 de 2
    • Remove the battery cover.
    • Locate the battery.
  12. Belkin F5L114 Battery Replacement: paso 12, imagen 1 de 2 Belkin F5L114 Battery Replacement: paso 12, imagen 2 de 2
    • Lift the battery up using the spudger.
    • The battery is taped down.
  13. Belkin F5L114 Battery Replacement: paso 13, imagen 1 de 3 Belkin F5L114 Battery Replacement: paso 13, imagen 2 de 3 Belkin F5L114 Battery Replacement: paso 13, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Gently unplug the battery from the motherboard using the tweezers.
    • Remove the battery.
Conclusión
Una persona más ha completado esta guía.
Un comentario
Hi, I would like buy another battery for my keyboard. May you help me please?
Rundy Henry - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 8
Ultimos 30 días: 58
Todo El Tiempo: 832
