Saltar al contenido principal
Beboncool Gamepad for Nintendo Switch Battery Replacement
Qué necesitas
  1. Beboncool Gamepad for Nintendo Switch Battery Replacement, Beboncool Nintendo Switch Gamepad Disassembly: paso 1, imagen 1 de 3 Beboncool Gamepad for Nintendo Switch Battery Replacement, Beboncool Nintendo Switch Gamepad Disassembly: paso 1, imagen 2 de 3 Beboncool Gamepad for Nintendo Switch Battery Replacement, Beboncool Nintendo Switch Gamepad Disassembly: paso 1, imagen 3 de 3
    • Use the plastic opening tool to remove the blue plastic grips from the sides of the controller.
  2. Beboncool Gamepad for Nintendo Switch Battery Replacement: paso 2, imagen 1 de 2 Beboncool Gamepad for Nintendo Switch Battery Replacement: paso 2, imagen 2 de 2
    • Use the Phillips #0 screwdriver to remove the seven 5mm screws from the back of the controller.
  3. Beboncool Gamepad for Nintendo Switch Battery Replacement: paso 3, imagen 1 de 3 Beboncool Gamepad for Nintendo Switch Battery Replacement: paso 3, imagen 2 de 3 Beboncool Gamepad for Nintendo Switch Battery Replacement: paso 3, imagen 3 de 3
    • Gently separate the two halves of the controller.
    • As the two covers come apart the L1 and R1 button, will fall free from the controller. Be sure not to lose them if they should pop out and fall.
    • Be sure to slide the small circuit boards out of the covers to be able to separate the two halves
  4. Beboncool Gamepad for Nintendo Switch Battery Replacement: paso 4, imagen 1 de 2 Beboncool Gamepad for Nintendo Switch Battery Replacement: paso 4, imagen 2 de 2
    • Use the Phillips #0 screwdriver to remove the two 3.5mm screws holding the circuit board in place.
  5. Beboncool Gamepad for Nintendo Switch Battery Replacement: paso 5, imagen 1 de 3 Beboncool Gamepad for Nintendo Switch Battery Replacement: paso 5, imagen 2 de 3 Beboncool Gamepad for Nintendo Switch Battery Replacement: paso 5, imagen 3 de 3
    • Lift the motherboard from the back case with the vibration motors and button boards attached.
  6. Beboncool Gamepad for Nintendo Switch Battery Replacement, Battery: paso 6, imagen 1 de 3 Beboncool Gamepad for Nintendo Switch Battery Replacement, Battery: paso 6, imagen 2 de 3 Beboncool Gamepad for Nintendo Switch Battery Replacement, Battery: paso 6, imagen 3 de 3
    • Carefully separate the battery which is adhered to the circuit board.
  7. Beboncool Gamepad for Nintendo Switch Battery Replacement: paso 7, imagen 1 de 3 Beboncool Gamepad for Nintendo Switch Battery Replacement: paso 7, imagen 2 de 3 Beboncool Gamepad for Nintendo Switch Battery Replacement: paso 7, imagen 3 de 3
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 562
