Saltar al contenido principal
Beats Studio3 Wireless Speaker Replacement
Qué necesitas
  1. Beats Studio3 Wireless Speaker Replacement, Ear Pad: paso 1, imagen 1 de 2 Beats Studio3 Wireless Speaker Replacement, Ear Pad: paso 1, imagen 2 de 2
    • Find the separation between the headset and ear cushion.
    • Use an opening tool to go underneath the separation site and split the pieces apart.
  2. Beats Studio3 Wireless Speaker Replacement: paso 2, imagen 1 de 3 Beats Studio3 Wireless Speaker Replacement: paso 2, imagen 2 de 3 Beats Studio3 Wireless Speaker Replacement: paso 2, imagen 3 de 3
    • You can also use your hands to remove it completely.
    • Pulling it off can be challenging; make sure to apply enough pressure.
  3. Beats Studio3 Wireless Speaker Replacement, Speaker: paso 3, imagen 1 de 2 Beats Studio3 Wireless Speaker Replacement, Speaker: paso 3, imagen 2 de 2
    • Remove seven 3.6 mm screws holding the speaker assembly in place using a Phillips #0 screwdriver.
    • Make sure the screws aren't close to the speaker; due to it being a magnet, the screws could get stuck and damage the speaker.
    • Open the speaker by pulling the top layer of the speaker.
  4. Beats Studio3 Wireless Speaker Replacement: paso 4, imagen 1 de 3 Beats Studio3 Wireless Speaker Replacement: paso 4, imagen 2 de 3 Beats Studio3 Wireless Speaker Replacement: paso 4, imagen 3 de 3
    • With a heat gun or hair dryer, heat the glue that is sticking the wires down until the glue softens.
    • Use a nylon spudger to remove the glue.
    • Pull on the wire to remove it while also removing the blue rubber band.
  5. Beats Studio3 Wireless Speaker Replacement: paso 5, imagen 1 de 3 Beats Studio3 Wireless Speaker Replacement: paso 5, imagen 2 de 3 Beats Studio3 Wireless Speaker Replacement: paso 5, imagen 3 de 3
    • Using a soldering iron to remove the cables on the charger port.
    • For help with soldering, check out the How to Solder and Desolder Connections guide.
    • Remove the two wires connected in the middle of the speaker using a soldering iron.
    • Remove the speaker from the headset.
Conclusión
Nayeli watts
Miembro Desde 03/16/23
474 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 95
Todo El Tiempo: 954
