Saltar al contenido principal
Beats Studio3 Wireless Battery Replacement
Qué necesitas
  1. Beats Studio3 Wireless Battery Replacement, Battery: paso 1, imagen 1 de 2 Beats Studio3 Wireless Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Use a pointed nylon spudger to remove the center circular panel on the right side of your device.
    • Be gentle while removing this piece as it is glued on with adhesive.
  2. Beats Studio3 Wireless Battery Replacement: paso 2, imagen 1 de 2 Beats Studio3 Wireless Battery Replacement: paso 2, imagen 2 de 2
    • Remove the four 3.5 mm screws using a Phillips #0 screwdriver.
  3. Beats Studio3 Wireless Battery Replacement: paso 3, imagen 1 de 3 Beats Studio3 Wireless Battery Replacement: paso 3, imagen 2 de 3 Beats Studio3 Wireless Battery Replacement: paso 3, imagen 3 de 3
    • Using a pointed nylon spudger, remove the tab located on the inner part of the headband labeled "R."
    • Place the nylon spudger in between the side panels and push inward going from bottom to top to separate both sides of the panel.
    • The panel will pop open after separating.
  4. Beats Studio3 Wireless Battery Replacement: paso 4, imagen 1 de 1
    • Place the nylon spudger underneath the battery, push inward and separate the battery from the inside.
    • Never use sharp tools to pry batteries. Metal spudgers can puncture an unprotected battery, potentially causing a fire.
  5. Beats Studio3 Wireless Battery Replacement: paso 5, imagen 1 de 2 Beats Studio3 Wireless Battery Replacement: paso 5, imagen 2 de 2
    • Use a nylon spudger to lift up the glue sticking the wires down.
    • Use a nylon spudger to lift the connector to disconnect the battery.
Conclusión
4 personas más completaron esta guía.
Equipo
3 comentarios
Should the glue be reapplied or is it okay to simply place back on?
Jake Allen - Contestar
the replacement batteries usually come with a gluepad on the back.
The connector its up to you - you risk the chance of the connector coming lose and u have to reopen the headset. But ill take the chance for now, lets see how it holds up without new glue.
seb -
Tengo una duda mis audífonos la batería esta full de voltaje pero me marca un rojo y no me prenden q podría ser o que solución podría darle
luis m cruz - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 11
Ultimos 7 días: 82
Ultimos 30 días: 348
Todo El Tiempo: 4,262
