Saltar al contenido principal
Beats Studio3 Micro USB-B Replacement
Qué necesitas
  1. Beats Studio3 Micro USB-B Replacement, Micro USB-B: paso 1, imagen 1 de 3 Beats Studio3 Micro USB-B Replacement, Micro USB-B: paso 1, imagen 2 de 3 Beats Studio3 Micro USB-B Replacement, Micro USB-B: paso 1, imagen 3 de 3
    • Remove the pad that is on the charging port side using an opening tool.
  2. Beats Studio3 Micro USB-B Replacement: paso 2, imagen 1 de 3 Beats Studio3 Micro USB-B Replacement: paso 2, imagen 2 de 3 Beats Studio3 Micro USB-B Replacement: paso 2, imagen 3 de 3
    • Remove seven screws from the earpiece using a Phillips screwdriver.
    • Pry the top panel away from the rest of the speaker using an opening tool.
    • There will still be wires attached, so be gentle.
  3. Beats Studio3 Micro USB-B Replacement: paso 3, imagen 1 de 3 Beats Studio3 Micro USB-B Replacement: paso 3, imagen 2 de 3 Beats Studio3 Micro USB-B Replacement: paso 3, imagen 3 de 3
    • Use the soldering iron to carefully desolder five different wires from their respective points.
    • After disconnecting the wires, gently push the charger upward using your fingers to detach it from the base. Be careful to avoid damaging any components
    • Position the new charger by aligning it properly with the base. Push the new charger into place, ensuring it fits snugly and securely.
    • Reattach the five wires to their designated points on the new charger by soldering them securely. Ensure each wire is correctly connected to its corresponding point to guarantee proper functionality.
Conclusión
Una persona más ha completado esta guía.
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 63
Todo El Tiempo: 441
