Introducción
Don't worry, Dr. Dre is here! Changing the batteries is probably the easiest replacement procedure you can perform, so don't stress out and you'll be fine.
Herramientas
No se especificaron herramientas.
Partes
The left speaker is the speaker that holds the batteries and does not have the power switch.
Place two fingers on each side of the cap. Press and twist counterclockwise to loosen the cap.
Once the cap is loose, simply lift the cap out to reveal the batteries.
Carefully pull the batteries out of their housings. When putting in new batteries, make sure that you place each battery in the correct orientation.
14 personas más completaron esta guía.
24 comentarios
hi man you post is help me a lot thank you..God bless you
Are u using 4A batteries on this? Please reply ASAP. The 3a batteries won't fit on my beats wireless studio.
They are 2 x AAA batteries. This is Beats Studio first generation which are WIRED headphones.
