Saltar al contenido principal
Beats Studio 3 Headband Replacement
Qué necesitas
  1. Beats Studio 3 Headband Replacement, Beats Studio 3 Headband: paso 1, imagen 1 de 1
    • Slide the headband down to reveal the the screws
    • Unscrew both screws from each side of the Headphones.
  2. Beats Studio 3 Headband Replacement: paso 2, imagen 1 de 3 Beats Studio 3 Headband Replacement: paso 2, imagen 2 de 3 Beats Studio 3 Headband Replacement: paso 2, imagen 3 de 3
    • Remove the foam pad
    • Remove the cushion pad
    • Remove the broken headband.
    • Keep the cushion pad and foam pad to the side.
    • When removing the cushion pad, you will have to use some force and will make a snapping noise, which is normal.
  3. Beats Studio 3 Headband Replacement: paso 3, imagen 1 de 2 Beats Studio 3 Headband Replacement: paso 3, imagen 2 de 2
    • Get the new headband and snap back the cushion pad together.
    • Put back the foam pad together.
  4. Beats Studio 3 Headband Replacement: paso 4, imagen 1 de 2 Beats Studio 3 Headband Replacement: paso 4, imagen 2 de 2
    • Screw in both screws on each side of the headphones.
Conclusión
  1. locate screws and unscrew
  2. remove cushion, foam, and broken headband
  3. remove any broken plastic inside the clasps
  4. get the new headband and place it on the headphones; make sure the letter B is on the left and the S on the right of the headphones
  5. place foam and cushion with the headband. It will make a snapping noise if done correctly
  6. screw in the screws
3 personas más completaron esta guía.
Ivan
Miembro Desde 08/22/23
190 Reputación
1 Guía escrita
Equipo
CSU Los Angeles, Team 3-3, Briggs Fall 2023 Miembro de CSU Los Angeles, Team 3-3, Briggs Fall 2023
CSULA-BRIGGS-F23S3G3
3 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 16
Ultimos 7 días: 61
Ultimos 30 días: 321
Todo El Tiempo: 1,836
