Saltar al contenido principal
Beats Solo 3 Left Hinge Replacement
Qué necesitas
  1. Beats Solo 3 Left Hinge Replacement, Left Hinge Replacement: paso 1, imagen 1 de 1
    • Use a spudger or opening tool to peel the earpad away from the left earcup.
    • Remove the tape around the earcup.
    • Make sure to do this step gently to avoid damage to the headphones.
    • Using a plastic or nylon prying tool is recommended to avoid damaging the device.
  2. Beats Solo 3 Left Hinge Replacement: paso 2, imagen 1 de 2 Beats Solo 3 Left Hinge Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove the three screws from the left earcup.
    • Gently remove the speaker.
    • The speaker is connected to the motherboard by soldered wires so don't pull or yank the speaker off the earcup.
  3. Beats Solo 3 Left Hinge Replacement: paso 3, imagen 1 de 2 Beats Solo 3 Left Hinge Replacement: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use a Phillips #00 screwdriver to remove two 0.4 mm screws that are holding down the audio jack's circuit board.
    • Use a set of tweezers to gently pull out the audio jack board.
  4. Beats Solo 3 Left Hinge Replacement: paso 4, imagen 1 de 2 Beats Solo 3 Left Hinge Replacement: paso 4, imagen 2 de 2
    • Use a soldering iron to desolder the seven wires attached to the audio jack board from the the left ear cup.
    • The two wires coming directly from the speaker to the audio jack do not need to be desoldered.
  5. Beats Solo 3 Left Hinge Replacement: paso 5, imagen 1 de 2 Beats Solo 3 Left Hinge Replacement: paso 5, imagen 2 de 2
    • Use a prying tool to separate the headphone cover.
    • Gently pry up and around the cover to ensure it comes off without breaking.
    • A plastic or nylon prying tool should be used rather than a screwdriver or metal spudger.
  6. Beats Solo 3 Left Hinge Replacement: paso 6, imagen 1 de 1
    • Now that the outer and inner panels are separated, pull the desoldered wires through the back of the inner panel.
  7. Beats Solo 3 Left Hinge Replacement: paso 7, imagen 1 de 1
    • To disconnect the three bundled connectors from the circuit board of the outer panel, pull the cables away from the socket in the same direction as the individual wires.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  8. Beats Solo 3 Left Hinge Replacement: paso 8, imagen 1 de 1
    • Gently pull the wires glued to the headband up.
    • You may use a small pry tool to wedge under the wires.
  9. Beats Solo 3 Left Hinge Replacement: paso 9, imagen 1 de 1
    • Pull back the rubber surrounding the left hinge.
    • Use a Phillips #00 to remove two 0.3 mm screws from the left hinge.
  10. Beats Solo 3 Left Hinge Replacement: paso 10, imagen 1 de 1
    • Pull the hinge out from the headband.
    • If the hinge is severely broken, it may come out in several parts.
  11. Beats Solo 3 Left Hinge Replacement: paso 11, imagen 1 de 2 Beats Solo 3 Left Hinge Replacement: paso 11, imagen 2 de 2
    • Fold the hinge and expose the metal pins holding it in place.
    • Use a set of tweezers to remove one of the metal pins.
    • Keep it for later use.
  12. Beats Solo 3 Left Hinge Replacement: paso 12, imagen 1 de 1
    • Separate the hinge from the bracket and remove them from the wires.
  13. Beats Solo 3 Left Hinge Replacement: paso 13, imagen 1 de 2 Beats Solo 3 Left Hinge Replacement: paso 13, imagen 2 de 2
    • Take your replacement hinge in hand and use tweezers to insert the copper plate it comes with.
    • Push the plate down into the hinge's inner groove.
    • This may require some force.
  14. Beats Solo 3 Left Hinge Replacement: paso 14, imagen 1 de 3 Beats Solo 3 Left Hinge Replacement: paso 14, imagen 2 de 3 Beats Solo 3 Left Hinge Replacement: paso 14, imagen 3 de 3
    • Feed the wires through the new hinge and bracket.
    • Clip the hinge and bracket together.
    • Fold the hinge and carefully insert its metal pin.
  15. Beats Solo 3 Left Hinge Replacement: paso 15, imagen 1 de 2 Beats Solo 3 Left Hinge Replacement: paso 15, imagen 2 de 2
    • Insert the hinge into the headband.
    • Pull back the rubber surrounding the hinge.
    • Use a Phillips #00 screwdriver to replace the two 0.3 mm screws that fasten the hinge to the headband.
    • Congratulations you have replaced the hinge! You may cycle back through the steps to complete reassembling.
Conclusión
  • To reassemble your device, follow these instructions in reverse order.
Samuel Moore
Miembro Desde 01/30/23
258 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 62
Ultimos 30 días: 271
Todo El Tiempo: 3,950
