Introducción
If your Beats Wireless Solo 2 Headphones do not feel comfortable on your ears while wearing them, this means the earpads are coming off, or the material covering the foam on the earpads is ripped. It might be time to consider changing the earpads. Use this guide to replace the earpads on your Beats.
The earpads are the most important part of the headphones when it comes to comfort. If you have bad earpads, your ears may hurt from the discomfort caused by the headphones, or you might just not want to wear the headphones in public because the earpads are ripped and look ugly.
Before using this guide, you will need to have your replacement earpads ready to go.
Before beginning, make sure to power off your headphones and disconnect from any external power source.
Qué necesitas
Set the headphones down on a flat surface.
Insert a plastic card in the wedge between the earpads and the solid part of the headphones.
Carefully pry the pads off the headphones. Go all around the pad to make sure you pry every part off.
Una persona más ha completado esta guía.
