Introducción
Involves opening up the Beats Pill XL and removing the X-clamps holding the batteries in place. Disconnect the battery from the logic board and remove it from the device. You'll need to disconnect a ribbon cable to easily remove the battery.
Qué necesitas
Using a plastic opening tool, pry the casing from the rest of the device.
Pry all the way around the edge and then pull apart.
Using a Phillips #2 screwdriver, remove the 8 (11mm pan head Phillips #2) screws holding down the the X-clamps.
Remove the X-clamps by simply lifting upwards.
21 personas más completaron esta guía.
7 comentarios
como saber se o problema da minha caixa e a bateria, ela nao esta carregando nem liga, a bateria porem nao esta dando 12v medicao, uma por sinal esta com carga negativa. no aguardo
Where can i buy these replacement batteries?
From here you can find a replacement battery
lisi -
It's under recall https://www.apple.com/support/beats-pill...
i think it's better to change a battery than buy a new one. And i was luck to find a replacement battery.lol
Jailene -
