Saltar al contenido principal
Bear 1000 Power Entry Module Replacement
Equipo médico
El fabricante de este equipo médico no ha avalado o contratado a iFixit ni a esta guía de reparación.
Qué necesitas
  1. Bear 1000 Power Entry Module Replacement, Air and O2 Blender: paso 1, imagen 1 de 1
    • Remove the ribbon cable at the connection on the oxygen blender control board.
  2. Bear 1000 Power Entry Module Replacement: paso 2, imagen 1 de 1
    • Mark the plastic hoses attached to the oxygen blender (so you can put them back on the same way) and then remove.
  3. Bear 1000 Power Entry Module Replacement: paso 3, imagen 1 de 1
    • The air/oxygen blender has two screws close to the control board. Remove them and remove the unit.
  4. Bear 1000 Power Entry Module Replacement, Air and O2 Inlet Manifold: paso 4, imagen 1 de 1
    • Remove the pneumatic and electrical connections labeled.
    • Remove the water trap bowls on the rear of the unit.
  5. Bear 1000 Power Entry Module Replacement: paso 6, imagen 1 de 1
    • Remove the four screws and remove the manifold.
    • Remove the two screws holding the power supply to the manifold.
    • Mark or label the 6 faston connections as to position and remove
    • Mark or label the two wires going to the power switch and remove at the power switch end
    • Using an allen wrench, remove the power cord retaining bracket.
  6. Bear 1000 Power Entry Module Replacement: paso 11, imagen 1 de 1
    • Using an allen wrench, remove the mounting screwa and nuts from the Power Entry Module.
    • After removing the heat shrink tubing, unsolder the two lower wires from the Power Entry Module, noting locations.
    • Solder the wires to the replacement module, covering the joints with heat shrink tubing.
    • Transfer the voltage selector drum from the original module to the replacement and reinstall.
Conclusión
Una persona más ha completado esta guía.
Eli Ferman
Miembro Desde 04/08/20
607 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S7-G12, Paton Fall 2020 Miembro de Cal Poly, Team S7-G12, Paton Fall 2020
CPSU-PATON-F20S7G12
2 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 66
