Saltar al contenido principal
Bear 1000 Air and O2 Inlet Manifold Replacement
Equipo médico
El fabricante de este equipo médico no ha avalado o contratado a iFixit ni a esta guía de reparación.
Qué necesitas
  1. Bear 1000 Air and O2 Inlet Manifold Replacement, Air and O2 Blender: paso 1, imagen 1 de 1
    • Remove the ribbon cable at the connection on the oxygen blender control board.
  2. Bear 1000 Air and O2 Inlet Manifold Replacement: paso 2, imagen 1 de 1
    • Mark the plastic hoses attached to the oxygen blender (so you can put them back on the same way) and then remove.
  3. Bear 1000 Air and O2 Inlet Manifold Replacement: paso 3, imagen 1 de 1
    • The air/oxygen blender has two screws close to the control board. Remove them and remove the unit.
  4. Bear 1000 Air and O2 Inlet Manifold Replacement, Air and O2 Inlet Manifold: paso 4, imagen 1 de 1
    • Remove the pneumatic and electrical connections labeled.
    • Remove the water trap bowls on the rear of the unit.
  5. Bear 1000 Air and O2 Inlet Manifold Replacement: paso 6, imagen 1 de 1
    • Remove the four screws and remove the manifold.
    • Remove the two screws holding the power supply to the manifold.
Conclusión
To reassemble your device, follow these instructions in reverse order. Calibrate and test the system to see if the replacement was successful
William Burns
Miembro Desde 04/06/20
285 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S7-G12, Paton Fall 2020 Miembro de Cal Poly, Team S7-G12, Paton Fall 2020
CPSU-PATON-F20S7G12
2 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 126
