Saltar al contenido principal
Beaded Bracelet Clasp Replacement
Qué necesitas
  1. Beaded Bracelet Clasp Replacement, Beaded Bracelet Clasp: paso 1, imagen 1 de 1
    • From the left end of the bracelet, string on a crimp bead and one end of the new clasp.
    • Bring the clasp and crimp bead 3 inches from the left end of the string.
  2. Beaded Bracelet Clasp Replacement: paso 2, imagen 1 de 1
    • Loop the left end of the string through the left side of the crimp bead.
  3. Beaded Bracelet Clasp Replacement: paso 3, imagen 1 de 1
    • Push the crimp bead up close to the clasp.
    • Push the crimp bead up as close as you can to the clasp.
  4. Beaded Bracelet Clasp Replacement: paso 4, imagen 1 de 2 Beaded Bracelet Clasp Replacement: paso 4, imagen 2 de 2
    • Use the bead crimp tool to squeeze the crimp bead shut.
    • Use scissors to cut off excess string.
  5. Beaded Bracelet Clasp Replacement: paso 5, imagen 1 de 1
    • Bead the bracelet from the right end.
  6. Beaded Bracelet Clasp Replacement: paso 6, imagen 1 de 1
    • After all beads are on, string on a crimp bead and then the other end of the new clasp.
  7. Beaded Bracelet Clasp Replacement: paso 7, imagen 1 de 1
    • Loop the right end of the string through the right side of the crimp bead.
  8. Beaded Bracelet Clasp Replacement: paso 8, imagen 1 de 1
    • Pull on the string to tighten the bracelet.
    • You do not want the beads spread out.
  9. Beaded Bracelet Clasp Replacement: paso 9, imagen 1 de 2 Beaded Bracelet Clasp Replacement: paso 9, imagen 2 de 2
Conclusión
2 personas más completaron esta guía.
Kelly
Miembro Desde 03/22/16
182 Reputación
1 Guía escrita
Equipo
2 comentarios
Awesome!! Its very beautiful [|bracelets] each step make this bracelets so easy. Thank you!! Keep it up
daniel - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 33
Todo El Tiempo: 2,373
