Saltar al contenido principal
Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015
Qué necesitas
  1. Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015, Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: paso 1, imagen 1 de 2 Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015, Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: paso 1, imagen 2 de 2
    • Remove the following pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.0 mm
    • Two 2.3 mm
  2. Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: paso 2, imagen 1 de 1
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    • Set the lower case aside.
  3. Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: paso 3, imagen 1 de 1
    • Peel back the warning label covering the battery connector.
  4. Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: paso 4, imagen 1 de 3 Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: paso 4, imagen 2 de 3 Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: paso 4, imagen 3 de 3
    • No metal tools!
    • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
    • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
  5. Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: paso 5, imagen 1 de 2 Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: paso 5, imagen 2 de 2
    • Remove the following T5 Torx battery screws.
  6. Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: paso 6, imagen 1 de 3 Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: paso 6, imagen 2 de 3 Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: paso 6, imagen 3 de 3
    • There is risk to damage the battery! (Do not use ANY metal tools - puncturing the battery can cause fire and possibly leak battery gel!)
    • Please note: carefully cut the duct tape layer under the battery with thin wire string. Pull back and forth slowly. Do not pry up with any metal tools.
  7. Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: paso 7, imagen 1 de 2 Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: paso 7, imagen 2 de 2
    • Be sure you did not damage the loopback of the track-pad!
    • Please lift up the plaque under the battery with metal spudger.
  8. Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: paso 8, imagen 1 de 2 Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: paso 8, imagen 2 de 2
    • Remove battery
  9. Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: paso 9, imagen 1 de 2 Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: paso 9, imagen 2 de 2
    • Using the flat end of a spudger, pry the trackpad connector.
  10. Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: paso 10, imagen 1 de 3 Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: paso 10, imagen 2 de 3 Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: paso 10, imagen 3 de 3
    • Unscrew the light-colored screws
    • Remove trackpad.
  11. Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: paso 11, imagen 1 de 1
    • Adjustment of trackpad touching level
  12. Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: paso 12, imagen 1 de 1
    • Good luck!
Conclusión
53 personas más completaron esta guía.
Equipo
AppleParts.PRO Miembro de AppleParts.PRO
Business
1 Miembro
4 Guías creadas
54 comentarios
Thank you! I was able to swap out new trackpad w/ these instructions.
Bobby - Contestar
Hi, Could I just ask where did you get your 'Handles' for the wire string? I bought some titanium wire a while ago but literally cant grip it. I have searched ebay etc but nothing is comeing up - Maybe my search terms aren't correct.
Thanks
Aaron - Contestar
Hello! You can use any strong jaws. We ordered holders in China.
Aleksandr ApplePartsPRO -
Hi, Thanks for that, sorry for the late reply. I have ordered a set from china so I'll see what they're like, in the meantime if anyone is interested I had some random parts laying around, I made a set out of a couple of plastic spudgers, some polymorph to enlarge the top which I sank a motherboard peg into which I can then screw some screws with the large heads into. Seems to do a pretty good job, i'll upload a pic if any1 is interested.
Aaron - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 34
Ultimos 30 días: 216
Todo El Tiempo: 83,222
