Introducción
This guide provides a step by step comprehensive method for the removal of the battery from the Zenbre SoundBank Z3. Unfortunately, the battery is soldered into the motherboard via wires, therefore this replacement guide will be a bit more difficult than a normal battery replacement guide. For more information on soldering and desoldering, refer to this article called, How to Solder and Desolder Connections.
Qué necesitas
Remove the four 4.5 mm silver Phillips screws that secure the plastic panel covering the motherboard.
Remove the plastic panel.
3 personas más completaron esta guía.
3 comentarios
Thank you for providing battery replacement instructions for the ZENGRE BlueTooth speaker system. They are very helpful.
Bendiciones. con que batería la reemplazaste? podrías enviarme un link para comprarlo, desde ya muchas gracias
MUCHAS GRACIAS!!!!
Sin embargo hubiese sido exelente pudiese mostrarse los tipos de batería con los cuales se puede reemplazar.
