Saltar al contenido principal
Basis Peak Motherboard Replacement
Qué necesitas
  1. Basis Peak Motherboard Replacement, Frame: paso 1, imagen 1 de 1
    • Flip the watch over and orient it such that the buckle is away from you and the back panel is revealed.
    • Maintain this orientation to follow the guide.
  2. Basis Peak Motherboard Replacement: paso 2, imagen 1 de 2 Basis Peak Motherboard Replacement: paso 2, imagen 2 de 2
    • Remove the four base screws using a size 2 TORX screwdriver to separate the back plate from the frame.
  3. Basis Peak Motherboard Replacement: paso 3, imagen 1 de 1
    • Disconnect the ribbon cable on the left side of the motherboard by using a spudger.
  4. Basis Peak Motherboard Replacement: paso 4, imagen 1 de 1
    • Use a spudger and apply pressure to the white plastic wall to the right of the motherboard. Use this to lever the electronics out of the frame.
    • The clips have small lips that you can put the spudger under to get more leverage.
    • Using any of the metal to pry out the electronics may damage some of the wiring. It is crucial to only press on the plastic.
  5. Basis Peak Motherboard Replacement, Motherboard: paso 5, imagen 1 de 1
    • Remove the right side ribbon cable by pulling it off with your fingers.
  6. Basis Peak Motherboard Replacement: paso 6, imagen 1 de 1
    • Use the spudger tool to poke out the exposed motherboard section as seen in the photo.
    • As always be careful when disconnecting the cables or batteries.
  7. Basis Peak Motherboard Replacement: paso 7, imagen 1 de 1
    • Put a nylon spudger underneath the battery's press-fit connector and lift up to free the ribbon cable and motherboard.
Conclusión
2 personas más completaron esta guía.
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 17
Todo El Tiempo: 931
