Saltar al contenido principal
Basis Peak Frame Replacement
Qué necesitas
  1. Basis Peak Frame Replacement, Frame: paso 1, imagen 1 de 1
    • Flip the watch over and orient it such that the buckle is away from you and the back panel is revealed.
    • Maintain this orientation to follow the guide.
  2. Basis Peak Frame Replacement: paso 2, imagen 1 de 2 Basis Peak Frame Replacement: paso 2, imagen 2 de 2
    • Remove the four base screws using a size 2 TORX screwdriver to separate the back plate from the frame.
  3. Basis Peak Frame Replacement: paso 3, imagen 1 de 1
    • Disconnect the ribbon cable on the left side of the motherboard by using a spudger.
  4. Basis Peak Frame Replacement: paso 4, imagen 1 de 1
    • Use a spudger and apply pressure to the white plastic wall to the right of the motherboard. Use this to lever the electronics out of the frame.
    • The clips have small lips that you can put the spudger under to get more leverage.
    • Using any of the metal to pry out the electronics may damage some of the wiring. It is crucial to only press on the plastic.
Conclusión
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 166
