Qué necesitas
wedge the plastic opening piece underneath the bottom left hand corner of the front frame. Pry the frame off of the Nook.
Remove every visible screw tying the chassis to the bottom frame using the T-4 attachment for the screwdriver in the iFixit screwdriver kit.
flip center chassis so that the back of the screen is facing you, and the hole is positioned in the bottom right corner.
Remove copper tape above the antenna, 3 quarters of the way up the left side of the nook.
Locate thin orange strip on the top side of the motherboard. Apply tweezers to the black casing that locks it into the motherboard (plastic piece will completely come out).
Locate the foam covered orange strip on the motherboard. Pull up (away from motherboard) so that it i no longer connected to the motherboard.
Lift motherboard away from the screen. Pull frame off of the screen.
Put the new screen back into place in the frame (the reverse of step 9). Place motherboard back into place on the back of the screen. And follow steps in reverse order to reassemble.
9 personas más completaron esta guía.
Un comentario
como faço para comprar a tela touch do tablet nook ce0984
sou de Fortaleza-Ceara - Brasil
meu e-mail é moreiragenesio@yahoo.com.br
